It is currently Mon Jun 15, 2026 3:43 am
 Post subject: Climate Control Lighting
PostPosted: Sat Apr 20, 2013 6:33 am
As I drive around in the early mornings with the weather unseasonably cold I turn on the heater. I have noticed though, the heater controls are labled perfectly for daylight use, but, they are not lighted with the dash and radio. Is this normal or do I have lights burnt out? Ironically, they went through the trouble to lable the heater thouroughly but the radio controls are unlabled, unlike a Charger or Coronet.
Leela: 1970 Dart 225 CID
Coulmn Shift TorqueFlite
7 1/4" Axle 2.76 Gears
Go ahead and save that weird car, the sedan, the 6 cylinder, the C-Body. If you want a big block musclecar and that's all you care about, your missing the point.
PostPosted: Sat Apr 20, 2013 8:48 am
behind the dash, on top of the heater buttons, is a small L shaped bracket with a (blue?) nipple on it. if you slide that blue nipple off, theres a bulb there for the heater controls. i might be able to get you a picture, since my dash is all apart currently.
70 Plymouth Valiant 4dr
PostPosted: Sat Apr 20, 2013 10:38 am
That would be much appreciated, thank you.
