It is currently Fri Jan 02, 2026 12:14 am
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
PostPosted: Wed Apr 24, 2013 10:09 pm
Car Model: 1964 Dart 270
Ok will check with Napa to see if they have them....ask for Bluestreak......?
http://www.napaonline.com/Catalog/Catal ... 0171068494
1964 Dodge Dart 270 four door. Three speed automatic 225 Slant with a Carter BBS carb.Image
PostPosted: Wed Apr 24, 2013 10:10 pm
Yes, like mentioned, that is all I run in my 440's
PostPosted: Wed Apr 24, 2013 10:13 pm
Is the link above a set with Bakelite....?
PostPosted: Wed Apr 24, 2013 10:23 pm
Yes, it sure likes it .......would need to see them in person to be sure. If you can see the weave and the ply build up, then yes.....
I see Harley Davidson uses the Blue Streak ones with a bakelite cam follower. Borg Warner makes them too....for Chevs and Toyota's. I just did a quick search. Our local Auto Parts here in Black Diamond has them....and I just got hooked on them especially on high rpm engines. The white nylon ones wont hold a gap very long.....before they go out of tune.
PostPosted: Wed Apr 24, 2013 10:27 pm
Ok Ill look at these and see if I see the weave and the poly build up on them at the parts store....Thanks again for your help and advice..... :)
PostPosted: Wed Apr 24, 2013 10:47 pm
http://www.ebay.com/itm/170867222784?ss ... 1497.l2649
This looks like a set of points like were mentioned above.......? :D
PostPosted: Sun Apr 28, 2013 5:10 am
Image Looks like Bakeite.......
PostPosted: Mon Apr 29, 2013 10:38 am
Yep! That will last a long time and not melt. Just smooth the follower with some 600 and put some synthetic grease on it....
It will take a lot of heat and will not melt like the white nylon.
PostPosted: Mon Apr 29, 2013 1:11 pm
Thanks Ted for all your advice on the Bakelite points........... :)
