It is currently Mon Nov 16, 2026 12:34 pm
PostPosted: Fri Apr 26, 2013 10:59 pm
Car Model: 1964 Dodge Dart GT - 1964 Dodge Dart Wagon
Howdy,
I've got a 1964 Dart Wagon that's got 3 on the tree.
I also have an A833 4 speed that I picked up (along with a hump, floor shift steering column, etc.).
I'd like to do 3-on-the-tree to 4-on-the-floor swap.
Will the A833 bolt up to the stock 3 speed bellhousing?
The A833 came with a Quicktime bellhousing. Will that bolt up to the Slant 6?
Can I use the same clutch/flywheel with the A833?
Thanks!
John
PostPosted: Sat Apr 27, 2013 2:56 am
For that year, the BHs are almost certainly different. The early/mid 60s 3spds had a dedicated BH.
You can crawl under and check. The 833 pattern is sort of an asymmetric/oblong trapezoid, while the 3spd is more a rounded off square. Make a few ruler measurements of your 833 at the front face and compare with the BH in the car.
833 BHs are not too hard to find.
 Post subject: Yes, no, maybe...
PostPosted: Sat Apr 27, 2013 7:44 am
Lou is correct.
You will keep the clutch and flywheel and Z-bar and linkage, TOB and clutch fork.
The 3 spd bellhousing will not accept the 4 speed for those years (up to 1974). You will have to check the quicktime bell to see if the pattern is the same as your 3 spd bell (if so then you can use it).
OD 4spd bellhousings are the easiest to get, on this side of the continent the 4.8"IBR 4 speed bellhousings are getting hard to find, they may be easier other areas of the US. (If going to an A-833OD I have a couple of bells I could part with.)
Good luck, it's a worth while change.
PostPosted: Sat Apr 27, 2013 7:51 am
Thanks guys!
One more that I think I know the answer to, but...
Is the A833 compatible bellhousing specific to the Slant 6, or will a bellhousing for a small block bolt up to the Slant 6 engine? I think I need a Slant 6 specific 4 speed bellhousing, right?
Thanks again!
John
PostPosted: Sat Apr 27, 2013 8:40 am
You need a slantrsix specific bell.
What pattern is the QT bell?
You may be able to leverage the QT bell to get a slant bell....
PostPosted: Sat Apr 27, 2013 9:11 am
The Quicktime is for a Small Block
Update - not Quicktime - it's a Lakewood...been a while since I looked at it...
John
