It is currently Fri Jan 02, 2026 10:08 pm
 Post subject: Dielectric Grease
PostPosted: Sat Apr 27, 2013 7:07 am
A quick question...
Doing the cap and rotor on the Volare today.
Just to be clear..do I put a dab of dielectric grease on the internal cap contacts?
Or will that screw up conductivity?
Thanks all.
1978 Plymouth Caravelle 2 Door Boat Tail 225 Super Six
1987 Chrysler 5th ave. 318 (Daily Driver)
1980 Plymouth Volare 2 Door 225 Super Six
PostPosted: Sat Apr 27, 2013 8:10 am
No. Clean and dry inside the cap. :D
PostPosted: Sat Apr 27, 2013 8:17 am
No grease.
Gotcha. Thanks much.
PostPosted: Sat Apr 27, 2013 6:02 pm
I put grease on the contacts because if it is vented it will let moisture in to corrode the contacts. If it is non-vented then the Ozone that is created under the cap will corrode the contacts, so that's just my 2cents.
Leela: 1970 Dart 225 CID
Coulmn Shift TorqueFlite
7 1/4" Axle 2.76 Gears
Go ahead and save that weird car, the sedan, the 6 cylinder, the C-Body. If you want a big block musclecar and that's all you care about, your missing the point.
PostPosted: Sat Apr 27, 2013 8:27 pm
I just put it in as is.
I'll keep checking on it periodically to make sure.
I totally appreciate your help guys.
Thanks.
 Post subject: But...
PostPosted: Sat Apr 27, 2013 9:29 pm
The grease gets messed up as the rotor passes the terminals at 3000 rpm...and it's worse if you used the MO-3000 rotor with the extended tip. Cap and rotor are a consumable, so they get replaced regardless of sitting or daily driving.
:wink:
PostPosted: Sun Apr 28, 2013 8:37 am
With the center post carbon dust and dirt that inevitably build up inside the distributor, the grease will become a grimy film, coating the underside of the cap and rotor, contributing to carbon arcs and cross firing.
Dielectric grease is meant to keep oxygen away from electrical connections. It is not meant to be subjected to an arc distribution system. Put the grease on the plug wire connections in the posts, sure. Just not inside the cap.
2¢
PostPosted: Sun Apr 28, 2013 2:34 pm
Ok I see, well what I did was a thin coat, not a dab, but I refresh it every so often. Seemed to reduce misfiring I had after putting grease on the contacts.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 19 guests
