It is currently Sun Jun 21, 2026 6:15 am
 Post subject: Amp gauge trouble
PostPosted: Thu May 02, 2013 12:52 am
Hey guys, Ive just recently got my old 74 duster running again. I changed the head gasket and after putting it back together my amp gauge starting acting weird. When i start her up it usually reads about one line before -40. When i accelerate, the gauge goes all the way down. I do remember the condenser being too close to the ignition coil and it sparked a couple times. I moved the condenser a bit farther away and that fixed it. Thats about the only electrical problem i had. Today i was driving back from work and started seeing smoke behind my dash. Looked at connection to amp gauge and it was a but burned up. Now after doing a bit of research i've decided to the amp gauge bypass. My question is. Would this solve my problem or is there something i should look into before doing the bypass. Oh and i forgot to mention that i put in a new voltage regulator thinking that could have been the problem.
PostPosted: Fri May 03, 2013 1:06 pm
Do SL6Dan's wiring mod with the two ten gauge wires and breakers/fuses from the alternator to the battery to take the load off the stock wiring and amp gauge. He describes the mod very well.
I did this a while back and have been very happy with the results.
You can see a few shots in the red link below.
