It is currently Wed Nov 18, 2026 12:44 am
PostPosted: Thu May 02, 2013 12:37 pm
so i got this pressure plate from a board member a while back and finally put it in. i thought i had the disc in backwards so i pulled the tranny to find this.
so now my question is how important are they? can i leave it alone. i cant get it out. the one on the bottom was pushed through some how and the ones that are missing didnt come with it. the pressure plate i took out originally didnt have any in it.
1966 Plymouth Valiant, 225, 3 on the tree, 8 1/4 3.21 sure grip, hyperpac, holley 650dp, holset h1c
PostPosted: Thu May 02, 2013 2:30 pm
For the price of a new PP and disc I would start over. If your clutch lets loose it can cause a lot of damage.
PostPosted: Thu May 02, 2013 3:21 pm
they Are Both Brand New, LessThan 100 Feet On Both Of Them.
PostPosted: Thu May 02, 2013 3:53 pm
OK.
But there are obviously things wrong here. If this was mine I would either start over or take the whole package to a driveline place and see what they can salvage.
Im pretty big on do it yourself but a clutch that is even a little unbalanced will never work very well and likely chatter.
Clutch chatter will wreck ujoints ,engine mounts , trans linkage, and any confidence you have in the car.
Taking a pressure plate apart at home is a risky endeavour.
When I first got the Valaint there were some chattering clutch issues. When I took it all apart the inside of the bell showed signs of a fairly significant clutch incident....pretty sobering. I replaced everything.
PostPosted: Thu May 02, 2013 5:04 pm
I guess A Better Question Would Be what Is The Purpose Of The Plugs?
Sorry About The Caps My Phone Is Messing Up
PostPosted: Fri May 03, 2013 6:05 am
I don't see what is causing you concern. Those little discs? Were they there before and maybe you just noticed them? Please explain.
PostPosted: Fri May 03, 2013 10:28 am
the little pressed in weights or what ever you call them that go in the holes for the springs. one of them has come loose. can i just pop it in and call it a day? i dont know what they are supposed to do. and i just put a cam in so im gonna be flirting with the 5k shifts and i really like my legs.
