It is currently Wed Dec 31, 2025 4:22 am
PostPosted: Fri May 03, 2013 8:17 pm
Car Model: 1964 Dart 270
Besides the manifold heat for the choke, does the intake need heat for correct air/fuel mixture? :?
PostPosted: Sat May 04, 2013 3:34 am
Since you are staying with the 1bbl, I assume this is strictly a "daily driver" car. With this type of car, you really want some manifold heat, for low rpm drivability. You are in Georgia, and do get cold weater, which is even more reason for manifold heat. I have never tried doing it on a 1bbl manifold, but if you really want headers, you could probably make a adapter plate to bolt up to the bottom of the intake manifold, and run hot water from the heater system, to it. It wouldn't warm up as quickly as being exhaust heated, but should work. Also use an electric choke.
PS: With headers, you might need to change the main jet in the carb, one or two sizes richer.
PostPosted: Sat May 04, 2013 4:50 am
Thanks Charrlie S looks like I'm staying with the stock manifold.....but headers sure do look nice! :D
PostPosted: Sat May 04, 2013 5:10 am
You could always go with "Dutra Duals". That would give you dual outlet and manifold heat and a provision for a choke. They would not only outlast headers, but also outlast the car.
PostPosted: Sat May 04, 2013 5:35 am
I have looked at those and that's a good option....thanks again......
PostPosted: Sat May 04, 2013 9:21 am
While they are shown as "not available" here, you may be able to locate one somewhere else, or fabricate your own.
Edelbrock Heat Stove Stack and Tube Kits 65951
http://www.summitracing.com/parts/edl-65951
DynoDave
1970 Plymouth Duster
1972 Dodge Charger Rallye
1977 Chrysler Cordoba
WPC # 12304
PostPosted: Sat May 04, 2013 11:10 am
That kit from Summit looks like a good option to DynoDave......thanks for the info......
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot] and 2 guests
