It is currently Mon Jun 15, 2026 4:04 am
PostPosted: Sun May 05, 2013 6:05 am
Greetings, I am going to switch out a 318 CI engine with a rebuilt Slant 6 in a 1960 Dodge D100 pickup. What problems and/or modifications can I expect? Thanks, lew
PostPosted: Sun May 05, 2013 9:11 am
Engine mounts, transmission, exhaust, throttle linkage and kickdown linkage (if equipped with an automatic) transmission. Those are the basics you will need to cover. There will be smaller items such as radiator hoses connecting to the radiator ad possible modifying the engine wiring harness to make sure all the connections are still made.
The crankshaft hub register changed sizes in 68 and depending on the year of the crank in the motor you are putting in and the transmission you are using you may have to deal with this issue.
EDIT: Sorry, I mistyped earlier. Manual transmissions do not need a kick down.
PostPosted: Mon May 06, 2013 5:22 am
You wrote ---motor mounts. are you referring to the location of the motor mounts on the frame, or the mounting blocks?? Thanks,Lew
PostPosted: Mon May 06, 2013 8:20 am
Possibly both. I am not familiar enough with the early truck k-frames to tell you whether or not the trucks use the same K-frame in V-8 and six cylinder applications. I do know that you will need different metal mounting brackets for the motor. You most likely will also need different rubber insulators for between the motor mounts and the K-frame.
PostPosted: Mon May 06, 2013 8:29 am
What type of transmission is in the truck?
 Post subject: Aha!
PostPosted: Mon May 06, 2013 9:16 am
If you do decide on the swap i have a set of these that are clean and ready to prime and paint. Will make a deal on them!
 Post subject: 318 CI switch to Slant 6
PostPosted: Tue May 07, 2013 5:06 am
both engines have a 4 speed tranny.
If I decide to make the engine switch I will contact you fro the mounts.
 Post subject: bell housing
PostPosted: Wed May 08, 2013 5:44 am
I posted a separate post under transmissions asking about the bell housing.
Thanks, Lew
