It is currently Wed Sep 30, 2026 7:09 pm
 Post subject: Cam grind for boost?
PostPosted: Sun May 05, 2013 6:56 pm
Engine is a 1965 225. Basically stock except for a super six manifold and a 350 cfm holley. Turbo is a TD04. Anyone have a good cam grind for this setup? It'll be between 10-12 psi. Daily driven, so I wouldn't want something too lumpy.
1965 Plymouth Belvedere II Turbo Project - SOLD
2002 Subaru OBS
1995 Lexus LS400 Race Car
PostPosted: Sun May 05, 2013 9:58 pm
I'm working on turboing mine right now. The advice i have gotten from my turbo friends is that low overlap cams work well, something like an RV cam grind. I am just using my stock cam until I have driven it under boost for a while then i can decide better where to fine tune from there.
PostPosted: Mon May 06, 2013 4:02 am
My advice would be to cruies over to the FAQ in the boost section that I built. I will cover about every question you can come up with. For short, a lot of people will recommend the stock cam. Shaker223 ran sub 12s with all stock and 340 springs.
225, Offenhauser, Holley 350, A833OD, 3:55, GM HEI,99 Durango starter
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
Operation Enduring Freedom 12- 13
PostPosted: Mon May 06, 2013 10:23 am
Actually, it was high 11s but with alot more boost than you are planning. A stock cam will make plenty of power. Spring upgrades are needed. Just watch the backpressure.
11.02 @ 120.56
Chassis dyno
PostPosted: Mon May 06, 2013 10:37 am
So 340 springs would work fine? And also, do you think with headwork (engine builder valves and port job) at 10-12# could get me into mid 12's? 2900# car, 2.76 gears, rebuilt 225/904, td04, super six mani, holley 350cfm.
2002 Subaru OBS
PostPosted: Mon May 06, 2013 12:49 pm
Shimmed 340 springs would work...IIRC 120# on the seat. You should be able to get into the 12's with the mods listed.
11.02 @ 120.56
Chassis dyno
PostPosted: Mon May 06, 2013 6:43 pm
Alright, thanks! I'll let you know how it works out.
2002 Subaru OBS
