It is currently Mon Nov 30, 2026 12:12 am
Post new topic  Reply to topic  [ 51 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Thu May 09, 2013 7:29 pm
mine looks like scenario 3, but at 19-18ish inches, but its not a hp engine, it has a oregon#125 cam
PostPosted: Sun May 12, 2013 6:19 pm
Just about all 225 slants had idle jet .033 for standard shift and .0315 for automatic. With this new gas The carburetor shop is saying to add .002 to idle jet size. http://www.thecarburetorshop.com/Ethanoluse.htm
PostPosted: Sun May 12, 2013 7:02 pm
In 1965 mopar was still using the small cams. Only 16 degrees overlap ,very little dilution of intake mixture from exhaust gas. http://www.slantsix.org/forum/viewtopic ... ght=#63838 Gas is different , cam is different , carb still the same. Get a no 66 drill bit .033 and check idle jet size. Thats the bigest stock size. If you have a spare idle tube jet try a no 65 drill .035. If .035 too rich put other idle tube back in.
PostPosted: Mon May 13, 2013 8:01 pm
I will check idle jet sizes. But I found that the choke diaphram leaks down, slowly, would that be a cause of intake leak, or would that section not effect actuall vacuum of motor? I have carb pulled off at the moment, so I cannot do the carb spray trick
PostPosted: Sat May 18, 2013 12:35 pm
So I guess the diaphram doesn't leak down, guess I didn't have the hose on all rhe way or something. I tried covering the airspeed but would only make it run worse if I covered it too much. I have the mixture screw 3.5 turns out. Reving it up will make the entire engine shake andslightly stumble.
I have yet to check idle jet size (lost my drill index with all the number and letter bits somewhere to check) I've been fairly busy and havnt hd much time to work on this. I do have jet kit for webers I can probably get an idea of jet sizes. But I have a feeling this isn't the problem..
PostPosted: Sat May 18, 2013 12:51 pm
How sure are you that your valve adjustment is good? I ask because your vac gauge shouldn't bounce at all. That usually indicates some form of valve sealing problem. An engine is an air pump- if you pull a plug wire off or have a vacuum leak cause a misfire, the engine should still suck, compress, & exhaust air- the vac reading might be lower than normal, but it should stay steady. If it gets worse after the engine runs awhile then I hope that it is because a valve rocker is a bit too tight. Otherwise it might be a valve stem sticking in its guide, a valve/seat problem (or possibly a broken valve spring).
I will say that this is true. The valves were adjusted to .008 on m engine on all cylinders by some moron. The car had an attitude and would idle in gear, I adjusted them myself and the idle got better, then I richened it up a bit, smoother.... yada yada and so on...
Leela: 1970 Dart 225 CID
Coulmn Shift TorqueFlite
7 1/4" Axle 2.76 Gears
Go ahead and save that weird car, the sedan, the 6 cylinder, the C-Body. If you want a big block musclecar and that's all you care about, your missing the point.
PostPosted: Sat May 18, 2013 1:41 pm
Valves are set a few thou looser then cam specs say, when previous carb worked okay, valves were set to highest vacuum
PostPosted: Sat May 18, 2013 4:16 pm
As you increase engine speed timing changes. Vacuum advance pulls on plate and the governor kicks in. For testing , remove hose to vacuum advance and plug , adjust intial timing plus or minus. ALso check firing order. I do not think it is main jet
PostPosted: Sat May 18, 2013 4:39 pm
firing order is correct, timing has been set already
PostPosted: Sat May 18, 2013 6:38 pm
Reving it up will make the entire engine shake and slightly stumble. Does this with and with out vacuum advance connected ? If so I guess that rules out ignition.
PostPosted: Sun May 19, 2013 5:19 pm
Doesn't change much if at all with dist disconnected. If I let it sit for a few minutes idling, itwill drop rpms real low and erratic vacuum reading. If I hit the throttle just a little bit it will fix it for a few mins again. It will also fix it if I cup my hands over the top then remove my hands. I've never been chasing after such a problem for so long...
PostPosted: Tue May 21, 2013 5:37 pm
Sounds like dirt or water in the idle circuit. I should have a BBS by the week end to look at. Last night for practice on a carter afb drilled and taped rivet plug, rivet came out while turning tap. New rivets just tap in with small hammer. Looking at pictures, removing that one rivet plug in the idle circuit will allow a straight shot with air or wire at the idle restriction .052. I will report what i find.
PostPosted: Wed May 22, 2013 10:49 am
Thanks please let me know
PostPosted: Wed May 29, 2013 6:42 pm
Just got carb http://i1275.photobucket.com/albums/y45 ... 36f309.jpg Clean out plugs are on the way.
PostPosted: Thu May 30, 2013 1:23 am
What is idle down channel?
