It is currently Fri May 22, 2026 8:06 pm
PostPosted: Tue May 14, 2013 10:52 am
Car Model: 87 B150, 1970 Valiant 4-door
what size cylinder should I use after a 73-76 disc/10" drum manual brake conversion (70 Valiant w/all 9" drums)?
PostPosted: Sun May 26, 2013 8:39 pm
Since no one else has chimed in, I would start out with stock size cylinders for the rear 10" drums on a 73-76 disc brake car. I'd also consider going with an adjustable proportioning valve instead of the stock combo valve from the disc car.
63 Valiant Wagon
225 - 4 bbl
 Post subject: Yep.
PostPosted: Sun May 26, 2013 9:40 pm
I'd go with stock cylinders from same said year of car.
The prop block is a point of contention as 2 different combo valves were used in those years, one is just hollow and drilled for the appropriate valving sized and most common in 1973-1975 cars....1976 (and certain later F-bodies) drum cars got that valve, and the disc brake cars got one that is much like those seen on the disc brake E-bodies, these seem to work better than the former version (probably because the 1973-1974 OEM caliper bores were slightly smaller, and the rear cylinders were of a different bore).
PostPosted: Mon May 27, 2013 12:38 pm
Thanks for all the replies.
Since posting this I found that I'd have to change my rear do do 73+ brakes.
(I didn't want to change rims or rear.)
I got stuck buying new front drums (old one warped).
I may as well get my money's worth out of that setup for now.
Should I return to this line of thinking (i.e. 73+) I don't know what the stock size is. (Rockauto lists like 4 different bores for every applicable year of every a body)
 Post subject: It's...
PostPosted: Mon May 27, 2013 12:47 pm
15/16" is correct for the LBP 10" rear drum brake rear cylinders.
 Post subject: Re: It's...
PostPosted: Mon May 27, 2013 3:47 pm
And I think 13/16 is used if you have a rear brake locking first problem with the 15/16
 Post subject: Yep...
PostPosted: Mon May 27, 2013 5:32 pm
Yep, those were used with the 73-74 smaller front caliper bores...expect a little harder pedal to get it to stop.
