It is currently Thu Jun 25, 2026 1:45 am
Post new topic  Reply to topic  [ 29 posts ]  Go to page 1 2 Next
PostPosted: Fri May 17, 2013 8:51 am
Car Model: 1964 Dart 270
Ok guys this is what I have, can I get some advice on the best way to install it.....its a 3 Ohm coil and the Ignitor upgrade.......? Can I just jumper off the side of my ballast resistor with 12 volts to the 3 ohm coil.....?
1964 Dodge Dart 270 four door. Three speed automatic 225 Slant with a Carter BBS carb.Image
PostPosted: Fri May 17, 2013 9:03 am
I have no ideas for that but, I would return it and get a HEI module and a single pickup distributor and then you can have a really good electronic ignition system for less than $100.
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Fri May 17, 2013 9:16 am
That's about what I have in this set, seems like everything I read says they work well.....as long as you hook them up right........ :D
PostPosted: Fri May 17, 2013 6:49 pm
That's what I have.
I put a jumper wire on the inside of the ballast resistor so it looks stock.
Or remove the ballast and hook up the 12v directly to the + on the coil.
Your timing will change after removal of the points, so you need a timing light.
PostPosted: Fri May 17, 2013 8:01 pm
Yes timing has changed, the coil gets hot. Never checked it before, so no sure if that's normal or not? I put a double spade connector on the 12 volt side of the ballast resistor, that will work won't it? Also any reason I'm seeing 12 volts on both sides of the resistor? It reads 12 volts on both side? Thanks for the help.......
 Post subject: Voltage regulator.....
PostPosted: Sat May 18, 2013 11:09 am
Ed what kind of voltage regulator do you use? My voltage regulator is gets hot, I do not know if its too hot or maybe its to wrong type for my car?
PostPosted: Sat May 18, 2013 3:20 pm
Homemade:
http://www.slantsix.org/forum/viewtopic.php?t=22124
PostPosted: Sat May 18, 2013 6:16 pm
Looks good, sounds like it work great too.......
PostPosted: Sat May 18, 2013 7:10 pm
anyone here ever tried one of these?
http://www.ebay.com/itm/Mopar-Voltage-R ... 1109922732
1964 Dart GT
PostPosted: Tue May 21, 2013 10:33 pm
Years ago for a '65 Barracuda, I bought a J.C.Whitney replacement regulator. It appeared very similar to the original, but when I opened it up it was mostly empty space and surface mounted electronics. Seemed to work just fine with a stock-type Mopar electronic ignition. It's likely that almost all the stock replacements now are electronic, as it's much cheaper than the original electro-mechanical design.
PostPosted: Wed May 22, 2013 6:56 am
I have had great luck with my Pertronix. Runs 6200 RPM and 260 HP with no trouble.
Yes, I believe almost all replacement regs for early cars are solid state now.
PostPosted: Wed May 22, 2013 9:53 am
I ordered the one I posted earlier. I let you know how it works!
1964 Dart GT
PostPosted: Wed May 22, 2013 6:42 pm
Hooked ballast coil back up to circuit and coil is running must have had too much voltage going to it heating it up........ :D
PostPosted: Thu May 23, 2013 9:51 pm
Are you sure you have a 3 ohm coil?
PostPosted: Fri May 24, 2013 4:26 am
Yes it says 3 ohm coil on the Flame Thrower decal on the side........?
