It is currently Sun Jun 21, 2026 12:57 am
 Post subject: Exhaust flapper
PostPosted: Fri May 10, 2013 6:25 pm
So if this thing doesn't rotate can it cause the engine to run hot?
 Post subject: Sorta...
PostPosted: Fri May 10, 2013 6:48 pm
If it's stuck in the 'diverter' position the hot exhaust gas gets mostly deflected out the tail pipe...if in the other position is keeps the floor of the intake hot which could nicely atomize the incoming gas, but if it also heats the air you get less than normal fuel or air getting delivered to the cylinder.
PostPosted: Fri May 10, 2013 8:00 pm
6 Pack Dart
"PB blaster" applied to shaft ends after a while a gentle tap with a small hammer to make shaft move side to side should free up the flapper. You might have to repeat several times, just be patient.
Richard
PostPosted: Sat May 11, 2013 3:29 am
It was stuck closed, I freed it up now I have to drive it on the highway and see if the temps stay normal
 Post subject: Another thing to note...
PostPosted: Sat May 11, 2013 8:49 am
Just FYI, one other thin to consider, my '67 had come with the Holley 1920 and had a low end jet in it (#54 I think)...that might also cause a lean condition exacerbating the overheating issue. Bumping it up to a #57 would help.
PostPosted: Sat May 11, 2013 2:01 pm
Well the rad was plugged and the heat rizer wasn't moving. I got a used rad out of a 79 pickup that had a 318 so its a 22" rad. I finally got the timing almost right and went for a ride. Still has a slight ping so I have to back off the timing a few more degrees. Its at about 3* after right now. That doesn't seem right to me though that the timing should be 5* AFTER TDC. Any way it doesn't go above 1/2 way on the temp gage now.
PostPosted: Sat May 18, 2013 3:40 pm
Timing should BE TDC plus or minus 2 1/2°
Leela: 1970 Dart 225 CID
Coulmn Shift TorqueFlite
7 1/4" Axle 2.76 Gears
Go ahead and save that weird car, the sedan, the 6 cylinder, the C-Body. If you want a big block musclecar and that's all you care about, your missing the point.
 Post subject: It actaully should be...
PostPosted: Sat May 18, 2013 7:00 pm
1967 225 with Holley 1920...TDC is equipped with CAP, 5BTDC all others.
PostPosted: Sat May 18, 2013 7:42 pm
Hmm OK, I learned something lol
PostPosted: Sun May 19, 2013 4:52 am
Well I guess it doesn't matter. I was 20 miles from Mason Dixon Dragway for this weekends race and the engine started knocking. Time to find a replacemant engine and start all over. :cry:
PostPosted: Sun May 19, 2013 7:25 pm
Hope ya got to enjoy the races and see some quick /6es. Bummer about the engine, maybe ya got it shut down before too much damage.
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
