It is currently Fri Nov 20, 2026 6:40 am
PostPosted: Tue May 21, 2013 7:24 pm
I have a 68 barracuda fastback, I am interested in putting a slant six in the canned tuna, the k member I have now is a spool type. not sure if its for a big block or small block. anyways, will a slant six fit on this spool k member? :?
 Post subject: Yes, but...
PostPosted: Tue May 21, 2013 7:28 pm
The engine will fit, but you are on your own to make a set of conversion motor mounts...since the hobby is more interested in putting the V-8 into the /6 car, and very few are interested in going in reverse, no one commercially makes the adapter to do it. If you have some angle or box iron and a welder you should be able to come up with a work around...otherwise you are left with swapping in a /6 K-member.
PostPosted: Tue May 21, 2013 7:30 pm
what about spool type slant six motor mounts?
 Post subject: Not the same...
PostPosted: Tue May 21, 2013 8:22 pm
No...
The 1967-1972 K-member could be overcome by some simple modifications like that or use of a set of /6 truck mounts, but the /6 1973-1976 K-member is purpose built for that engine only in stock form, the driver's side cradle is quite a few inches taller than the passenger side cradle, on the V-8 K they are the same height...the driver's side mount on the /6 doesn't make up that extra bit the K-member does... he would have to cut off the mount and extend a few inches in height, or make a cradle adapter to bolt through the V-8 cradle and then receive the end of the /6 motor mount.
This picture will show what he needs, note the driver's side mount by the steering box mount is higher, the V-8 K would have mounts similar to the passenger side mount but on both sides...
PostPosted: Wed May 22, 2013 5:07 am
Just out of curiosity (I know), would the V8 K member be worth enough to sell or swap for a \6 one?
Mattelderca
78 NYB (gone now), two S series, three old Snow Cruisers and a Doo.
 Post subject: Possibly...
PostPosted: Wed May 22, 2013 7:09 am
If it was a big block MP K-member, then yes...if a small block, then possibly, it depends on the demand in the area but with conversion mounts available people don't need the PITA it is to swap out the /6 K-member anymore, they just swap the bars and work brakes/suspension items and are done with the upgrade.
PostPosted: Wed May 22, 2013 8:39 am
I bought a slant spool mount K for $25. I was wanting to swap it for a spool small block K. I tried to swap it for a SB one. I had lots of takers,just none close by.
There is poly mounts out there for the spools!
Being in CA I would post on Moparts and bet you find many who will swap with you!
Edit: don't forget the spool tranny mount too!
PostPosted: Wed May 22, 2013 9:37 am
I did this in the past by making-up special spool mounts for the SL6.
The car was also a 68 Barracuda that we used for drag racing. We would swap between the SL6 and a 440 V 8 engine... a number of time per season.
We "messed" with the heads of a lot of people at the track... by running the car and "showing-off" the Slant Six, as it ran high 13's and then running low 12's in the same car, the next week! :shock: :lol: :wink:
See this photo for the left side spool mount. (real long, to reach down to the V 8 location)
PostPosted: Wed May 22, 2013 11:09 am
Thanks Doc! :D
I was wondering about using the K member from the Street/Ruster/ChumpCar Duster...
It's a SL6 K modified for the Schumacker V8 kit...
Instead of re-reworking the K member, I can just extend the mount bracket.
Schweeeet! :D
 Post subject: Lol..
PostPosted: Wed May 22, 2013 3:38 pm
Looks like you need 2 old spool mounts, and a buddy with a cut off wheel and a high power outlet for his welder and it's golden...
(Also helps to bring a 6 pack as payment too...LOL).
:wink:
PostPosted: Thu May 23, 2013 6:40 am
You offerin' Battle Buddy? :D
I'll be there this weekend! :lol:
PostPosted: Fri May 24, 2013 8:20 am
If someone doesn't come get the Dart soon I will sell the K out of it................. :lol:
PostPosted: Fri May 24, 2013 5:33 pm
I'm waitin' on YOU to tell me when I can come and get it! :shock:
You were gonna send me some pics too... :lol:
PostPosted: Sun May 26, 2013 7:11 am
Do I send them to an imaginary email?
PostPosted: Sun May 26, 2013 3:50 pm
:roll: :lol: :roll: :lol:
I'll give it to ya again... :wink:
I THINK it's also available at the bottom of each of my posts... :lol:
