It is currently Thu Nov 26, 2026 6:51 pm
 Post subject: Weber 38 jet sizes?
PostPosted: Tue May 28, 2013 11:55 am
I've been running a 32/36 for a while and decided to try the 38/38 on my stock 1985-spec motor. I'm liking the 38 but I'm getting some ping at 3/4-WOT during up-hill climbs. I swapped the 145 mains with 170s and it still pings (less than with the 145s). Timing is currently 5-BTDC base, 50-BTDC total.
I'm planning to order some jets but wanted to check anyone here that might steer me in the right direction and possibly save some money on my selections.
-Thanks
1985 Dodge B250 Van
 Post subject: Reduce timing...
PostPosted: Tue May 28, 2013 12:09 pm
50-BTDC total.
50 is a bit much for a van 44-47 is a better range for even flat road driving in a heavy underpowered brick. Richening the mix will eliminate some detonation by allowing chamber heat to be used to vaporize the excess fuel and that being expelled out the exhaust system, but not eliminate all of it.
PostPosted: Tue May 28, 2013 12:24 pm
Thanks D.Idiot.
I mapped the curve yesterday and wanted to make some changes. mech advance is, if I recall correctly, somewhere around 38-deg. I'll have to check my notes when I get home. What would be optimum mech advance limit?
1985 Dodge B250 Van
 Post subject: Yikes!
PostPosted: Tue May 28, 2013 12:33 pm
What is your vacuum advance range? If you have 17 here then I would limit the mech advance advance to be 30....if you have more vacc. advance you may need to limit the pod through adjustment or a new one.
Typically on "trucks" I try to get 8 degrees of base + 22 degrees of mechanical and then let the 17 from vacuum advance fill in from there...this will vary based on build and rear gearing though....
PostPosted: Tue May 28, 2013 12:36 pm
Total mechanical advance usually ends up right around 30° with a 225. They usually idle a little better with more than 5° initial too. This means reducing the amount of mechanical advance available. I weld up the slots in the advance plate and then file them to the proper length.
PostPosted: Tue May 28, 2013 12:48 pm
Thanks guys,
I thought 38 was too much. That's why the base is @ 5. I'm going to limit mech advance first and go from there.
1985 Dodge B250 Van
PostPosted: Wed May 29, 2013 5:29 am
The current distributor has 28* mech advance. I found an MP 3690788 in my pile that I'm going to try. As far as I can tell, that one has 20* advance built in. Can someone confirm this? Also, it has one red spring in it so I think I'll be adding a spring. I'll map it with just one spring first then go from there. Vac adv is 7R.
I think this setup will get me close to what I want.
1985 Dodge B250 Van
 Post subject: Nope...
PostPosted: Wed May 29, 2013 7:18 am
No need to map the single red spring...it's all in by 800-1200 rpm as the drag racer needs 100% advance right off the bat with no curve... You'll need a spring kit or the springs out of a late distributor with the 9R or 11R governors to get it close to right. The 7R needs to go and you need the vac. can out of a 1973-1974 distributor to get the 17 degrees of vacc advance...if not available order one SMP VC-239 or a Wells 3034.
PostPosted: Wed May 29, 2013 7:44 am
I have a one heavy and one light spring in stock. Can't id them more at this time. Which should I try adding first?
The currently installed dist curve is 750RPM 2*base, 21*@1500, 30*@3000. Maybe use those springs?
I'll swap in the 17* vac can from the current dist.
Thanks for your input.
1985 Dodge B250 Van
 Post subject: Yes and no...
PostPosted: Wed May 29, 2013 7:51 am
Springs are not 100% universal, the loop heavy spring is tailored to the length of the governor slot... if you put a long slot spring, say from a 15L 1974 distributor, into a 1976 11R governor distributor the full coiled spring will be the only thing governing the timing....
PostPosted: Fri May 31, 2013 5:49 am
I installed the MP dist with the single spring and achieved 8*base, 30*mech, 46*total. It runs real good even with the fast curve. Idle is great, throttle transition is smooth and no pinging. Now that I have the timing sorted out, I'm going to address the mixture. Currently running the 170 mains in the Weber which may be rich and possibly covering up any problems associated with the fast curve.
Thanks for the guidance fellow slantheads.
1985 Dodge B250 Van
PostPosted: Fri Jul 05, 2013 4:52 pm
What jets were you running with the 32/36?
I have the K551 for Jeep and was wondering how close it was or if i will have to rejet it.
Thanks
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
 Post subject: 32/36 jets
PostPosted: Fri Jul 05, 2013 6:54 pm
Let me give you the long answer so I don't misguide you. Keep in mind that I had tuned this carb around a not-so-optimal timing scheme.
The 32/36 was originally set up for a 2.2 with 145/145 mains. I changed those those to 160pri/170sec and that seemed to work well even with my sub-par timing. The idle jet was too small for the 225 so I opened it up incrementally until I got the idle mix screw in spec (no more than 1-1/2 out). Sorry, I don't know what size I ended up with. I can't find my notes.
I ran the 32/36 on a Volare and my van it performed well, but the 38 makes noticeably more power and I prefer it.
1985 Dodge B250 Van
PostPosted: Fri Jul 05, 2013 7:01 pm
Ok thanks for the info.
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 7 guests
