It is currently Mon Nov 30, 2026 12:29 am
Post new topic  Reply to topic  [ 51 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Sun Jun 02, 2013 1:43 pm
This is the idle down channel . Also shows rivet plug hole for clean out. Sorry about long link. http://media.photobucket.com/user/Dougl ... 6498281872
PostPosted: Sun Jun 02, 2013 2:11 pm
Idle horizonnal channel about one inch long. Dirt being heavier than fuel or air will settle out here and clough up channel. This carb was 80% blocked. http://media.photobucket.com/user/Dougl ... 3604470948
PostPosted: Sun Jun 02, 2013 2:56 pm
The area under the main jet is the lowest part of the carb.Dirt will tend to settle here.This is the same place the idle tube gets fuel. Using 2 small flat blade screw drivers as wedges will allow removal of the high speed plug. http://media.photobucket.com/user/Dougl ... 3861213058
PostPosted: Sun Jun 02, 2013 3:49 pm
Here it is removed. The plug is top right of picture sitting on carb. http://i1275.photobucket.com/albums/y45 ... bb75ad.jpg
PostPosted: Sun Jun 02, 2013 5:52 pm
The idle air bleed bushing is pressed in . Make sure its still in there. The hole at top of idle down channel is blocked off by gasket? An air leak there would cause lean condition. On the idle restriction in the horizonnal channel, its right at the very start ,real close to idle tube.Gently work wire all the way threw. Clean out rivet plugs not here yet.My machinest has suggested taping horizonnal channel and use threaded set screws.My carb is 1970 ,just a little bit different.
PostPosted: Wed Jun 05, 2013 9:35 pm
Tore into both carbs, niether had much junk in the idle bores. Did measure a few things though.
First carb I had problems with
Tag#3239
Air bleed .0585
Main vent tube .023
Idle jet .031
Main jet .0625
Throttle plate bore 1.562
Second carb (most recent) carb I've been having problems with
Tag#3840s
Air bleed .063
Main vent tube .0345
Idle jet .030
Main jet .066
Throttle plate bore 1.687
PostPosted: Sat Jun 08, 2013 7:17 am
The Idle restriction in both carbs should be .052 .
PostPosted: Sat Jun 08, 2013 9:58 am
I measured where it presses into the center of the bore of the carb. Those were thr mesurements I got. I believe this 2nd carb was untouched before me. Looked to never hadbeen pulled apart.
PostPosted: Sat Jun 08, 2013 5:55 pm
Larger restrication .0345 in second carb may be thats why it idles better? After pulling clean out plug and cleaning carb my restrication only measured .028. My theory here is that 40 years of oxidation and corrosion have made the hole smaller.Used rust penetrating oil and woked drll bit back and forth. Also put a 90 degree bend in stiff wire and cut to length, So it would just fit down where the idle tube goes. This way i could push from both directions.Put the air to it and now have nice clean hole of at least .052.
PostPosted: Sat Jun 08, 2013 7:59 pm
Restrictor is the long tube with stagard 4 holes correct?
PostPosted: Sun Jun 09, 2013 4:47 am
No Thats the main vent tube
PostPosted: Sun Jun 09, 2013 12:10 pm
What is the restrictor then
PostPosted: Sun Jun 09, 2013 2:06 pm
Took some more picutures,To better identify componets and locations and get us on the same page. The idle restriction connects to the same bore the idle tube screws into.So does idle air bleed.Looking at top of idle tube just under screw threads are 4 holes.At that same level in that bore is where the idle restriction is.
PostPosted: Sun Jun 09, 2013 2:07 pm
PostPosted: Sun Jun 09, 2013 2:32 pm
I made it easier for us lazy folks who don't like to click links. It is just too much effort, sometimes. :mrgreen:
