It is currently Mon Nov 30, 2026 12:12 am
Post new topic  Reply to topic  [ 51 posts ]  Go to page Previous 1 2 3 4
PostPosted: Sun Jun 09, 2013 2:37 pm
Image The idle restriction bushing is only 1/8 inch long,sets just inside that bore.
PostPosted: Sun Jun 09, 2013 3:41 pm
Image Use smaller wire to start,small paper clip is stiff enough. Cut to length, just short enough to fit down idle tube hole,it will still be long enough to reach and go threw restricator.
PostPosted: Sun Jun 09, 2013 4:31 pm
Image When you look down the idle tube hole,the idle air bleed hole will be under the last thread. 90 degrees away the idle restrication is in the threads 2 threads from up from last screw thread. Looks like buggered thread.
PostPosted: Mon Jun 10, 2013 8:13 am
Looking at the restrictor, seems to be perfectly clean. I don't hsve anything to measure that deep into the carb, but does not look to be corroded or blocked at all. Thank you for the detailed pictures, they will help a lot of people. Still curious why the carb won't work. I got a new gasket kit on order to put it back together and give it another go..
PostPosted: Thu Jun 13, 2013 6:38 pm
I got everything back together and still have a fluctuating vacuum, and stumble uppon slow excel.
PostPosted: Fri Jun 14, 2013 7:04 pm
https://www.youtube.com/watch?v=u87OkW6 ... ata_player
Here is a video of my vacuum gauge. At one point you can hear and see the idle kick downeven lower at random, and cause even worse vacuum fluctuating. You can also tell tye stumble as I slowly rev. Timing is at 10degrees. And acts the same with dist vacuum disconnected.
