It is currently Mon Nov 30, 2026 7:00 am
 Post subject: Triple Webers
PostPosted: Mon Jun 10, 2013 6:16 pm
Awhile back I got a good deal on a matched set of Italian 40DCOEs. I'm wondering how well they would work on a slant (I do have an Aussie triple Weber intake and linkage) or would it have been better to source a set of 45's
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
 Post subject: Webers
PostPosted: Mon Jun 10, 2013 6:44 pm
I never have run them, but from what I have read, the 48's are the ticket. I would think the 40's would be great to 4500 but might start to fall off after that. That being said, I would think the area of 3 40 dcoe's would be greater than the 4 barrel AFB that the hyper pak ran and that motor would go 7000+. And with the shorter ram, I don't see why it would not work great on the street.
PostPosted: Mon Jun 10, 2013 9:20 pm
I would use what I had first. Then, if more carb is needed, you've already done the prep work. Upsizing the carbs should be a piece of cake.
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
PostPosted: Thu Jun 13, 2013 6:10 am
40s should work well on up to a medium/hot build, but not an all out race engine. The current record (AFAIK) for a NA slant 6 is around 370 HP with 45 DCOEs. Tilley tried 48s, but did not make more power.
PostPosted: Thu Jun 13, 2013 9:16 am
40 DCOEs are often used on 1600cc engines (with the proper venturi/choke). That's a 2400cc 6 cylinder. If you're running a hot, but streetable 170 I think they are a good choice, but for a 225 they are going to be a restriction on all, but very mild combinations. If you're doing it for the WOW factor, sure, but for performance use they are small. Alfa Romeo guys use 48 DCOEs on 2000cc engines and make more power than with the 45s, but they are turning higher RPM than 99% of the built 225s out there.
