It is currently Mon Nov 30, 2026 10:13 am
 Post subject: Wear on cam lobes
PostPosted: Tue Jun 11, 2013 6:13 pm
I've been looking at this forum for years and finally decided to register. I recently pulled my slant out of my 1970 Dart to install a cam and to have the head ported, polished, and shaved, with larger valves installed. When I pulled the cam, I noticed that the lobes were wearing towards the rear, as if the cam was not fully pushed back. I did not see a plate or any other devise that keeps the cam in position. Is it held in place by the timing chain along with the crank gear? If so, could the crank gear not be positioned correctly? The previous owner said it had been rebuilt and by the internal condition, it looks like a fresh rebuild. Any advise would be greatly appreciated. Thanks
I don't always hotrod, but when I do, it has a six cylinder. Stay slanted, my friend.
PostPosted: Tue Jun 11, 2013 6:25 pm
6 Pack Dart
Look at last picture in this post (first set of pictures) this is what most cams wear like.
http://slantsix.org/forum/viewtopic.php?t=52322
Richard
 Post subject: And...
PostPosted: Tue Jun 11, 2013 6:27 pm
It is also held in place by the oil pump gear and distributor gear as well.
PostPosted: Tue Jun 11, 2013 7:24 pm
The solid lifters that were removed had no signs of wear. Can I assume that the cam has not had enough time to wear evenly? I have one more question that is slightly related. There is a ring that rides on the crank shaft between the timing chain cover seal and the crank timing gear. Does it matter which direction it faces; convex towards front or back. Not sure what purpose it serves. Thanks for the input.
 Post subject: Ok...
PostPosted: Tue Jun 11, 2013 7:38 pm
The lifters when put end to end should have a little "wobble", the cam won't be perfectly "flat" worn as the lifters have to "spin" in their bores (when the engine is running and the valve cover is off you would witness this as the pushrods will also spin...
The "sheet metal" ring or 'dish' is called an oil slinger and is most common on 60's slant six engines and V-8's, it was used randomly through the 70's...the purpose of it is to keep oil off the crank seal in the timing chain cover and preventing a leak at that opening...if you picture the hole is at the bottom of the "dish" the outside bottom is against the crank timing chain gear and the "rim" of the bowl will be toward the timing chain cover.
PostPosted: Tue Jun 11, 2013 8:00 pm
Thanks, Duster man. I should be able proceed now.
PostPosted: Wed Jun 12, 2013 7:56 am
FYI...
The cam lobes have a slight angle ground onto the lobes, to promote the lifters to spin. That is the reason you see the contact "path" along one edge.
PostPosted: Wed Jun 12, 2013 4:41 pm
Thank you Doc.
Users browsing this forum: Ahrefs [Bot] and 3 guests
