It is currently Sun Nov 29, 2026 10:36 pm
Post new topic  Reply to topic  [ 64 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Wed Jun 12, 2013 9:32 pm
0225r 5 28 F
PostPosted: Wed Jun 12, 2013 9:53 pm
The stamp is on the block. Not the head. Do the spark plugs fit down in the head inside spark plug tubes, or do they stand out from the head?
Just about any head could have been bolted to the '71 block. (If I guessed what the first letter was correctly.) Now we're kicking over another kettle of fish. :lol:
PostPosted: Wed Jun 12, 2013 10:01 pm
They fit down into the head. Why is this a better engine?
PostPosted: Wed Jun 12, 2013 10:29 pm
Better than?
A '71 head doesn't have induction hardened valve seats. A '72 head would have them. All the "Peanut Plug" heads had hardened seats.
There are "Best" to start with heads, but if your going into the engine, you can make a lot of improvements to any of them. '72 and later would be preferred though.
Some folks prefer the Peanut over the Drool tube head due to the drool tube being more prone to leaks. Other's prefer the Drool tube, as it's lighter, and spark plug availability opens up.
Early heads, like the '63 didn't have improved combustion chambers. If your going to build the engine mildly, it really doesn't matter what you start with. As compression comes up, the improved chamber becomes important quickly. Once you pass other way points, no matter what you start with becomes less relevant in some aspects, and more so in others. Doesn't sound like your building out there in the performance ether though.
If you hit the Home button above, then click on Articles, there is a wealth of knowledge stored there. Give it a long hard look. Down near the bottom of the articles is a section related to heads, blocks, cranks and such. That will tell you quite a bit. Look at the articles about head mods, and what to look for. You will be able to identify what your head is by looking at the combustion chamber once you have it off. The hardened seats will require looking up the head casting number, and dates.
With a 1963 car sporting a '71 engine, and a two barrel, there's no telling what that head might be. The preceding three items never came bolted to one another from the factory. Depending on what the crank is, you may have an early transmission, or a late one. Late cranks can take a ring to accept the early transmission. Or the crank might be an early one, or.... The list goes on. An early transmission can't be bolted to a late crank without extra work.
Did you get any documentation, or talk to the P.O. ?
PostPosted: Thu Jun 13, 2013 9:49 am
55cc and the pistons were almost to the top 5 sheets of paper...i have no bore measure
PostPosted: Thu Jun 13, 2013 10:00 am
Ok so after i was able to clean the block some...the number on top r 0225r 5428 e and there are aslo numbers on side plate of 330 4 and 0320 aawj and head number is 4104362
PostPosted: Thu Jun 13, 2013 10:23 am
79-80 head
PostPosted: Thu Jun 13, 2013 10:37 am
PostPosted: Thu Jun 13, 2013 4:09 pm
That's different. It's a 76 built engine.
Better start looking things up in the Articles, 'cause that head isn't a drool tube. The spark plugs are not inside the casting of the head.
Go to Google and do a search for the calculators. It will give you the exact date.
PostPosted: Thu Jun 13, 2013 4:16 pm
drool head? bad or good? So what to do from here?
PostPosted: Thu Jun 13, 2013 4:20 pm
Go to the articles section I mentioned and look it up. :D
Please go do your research. We've gone to a lot of trouble to make this information easy to access.
I'm not going to tell you how to build your engine.
PostPosted: Thu Jun 13, 2013 4:22 pm
PostPosted: Thu Jun 13, 2013 4:37 pm
the "dime size dot"...I dont understand that. Is that my head or what?
PostPosted: Thu Jun 13, 2013 4:46 pm
Are we in a better mood now? :lol:
There should be no dime size dot in the combustion chamber of your head. Look at the surface across from the spark plug. If there is a rasied dot there, it is not a 79-80 head.
The dot isn't a complete circle.
PostPosted: Thu Jun 13, 2013 4:50 pm
ok so i've reread that article about 10 times now...so how i'm understanding it is my head is the better more improved head...correct?
How much should i get taken off of my head?
