It is currently Sun Nov 29, 2026 10:17 pm
Post new topic  Reply to topic  [ 64 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Thu Jun 13, 2013 5:31 pm
Yes, and we need to get a solid measurement of how far down the hole you are. If your going to rebore, you can't take the measurement now. The new pistons will deck out differently than the current pistons.
PostPosted: Thu Jun 13, 2013 5:33 pm
...How much should i get taken off of my head?
You need to take measurements and then work-out a DCR number, to know how much to mill-off the head.
PostPosted: Thu Jun 13, 2013 5:36 pm
Did all the chambers come out at 55cc? You may find that the chambers vary considerably. Sometimes your lucky, and they are very similar. I'd love to start with a head that was like that! :lol:
PostPosted: Thu Jun 13, 2013 6:04 pm
All CC were pretty close to one another. The cylinder holes all look good no scaring. I will take measurements tomorrow to see if they are within spec. If they are, i am only going to hone it. Can i keep my current pistons or do i go to a forge piston? That is if they are in spec.
PostPosted: Thu Jun 13, 2013 6:05 pm
And I really appreciate everything! I dont comprehend to well when reading articles. Thats why I ask for break downs. lol :)
PostPosted: Thu Jun 13, 2013 6:06 pm
What do i need to measure on my head? To see how much I need to take off?
PostPosted: Fri Jun 14, 2013 3:55 am
Looks like you are ready to play with this calculator.
screw around with the numbers .
hours of fun.
http://www.kb-silvolite.com/calc.php?action=comp
remember 8:1 DCR should be safe with any fuel.
see this thread for details to input into the calculator.
http://www.slantsix.org/forum/viewtopic ... ht=#379657
I believe the number for skimming off the head is .006" per cc.
so taking off .060" will reduce combustion chamber cc by 10cc. for example
Brendan.
1963 AP5 Valiant 225 PB 904 Stock except extractors & 2 1/4 inch exhaust.
1962 S series valiant 225 PB auto. factory every thing. Full restoration job.
Currently on hold till AP5 is on the road.
PostPosted: Fri Jun 14, 2013 4:10 pm
So i have been playing around with the link provided above. I'll start off by saying that I wanted around 10.5:1 compression. After playing with the number a little bit. I came up with SCR of 10.548:1.....That is with .060 off the head and .100 off the block and flat top pistons. Is that safe numbers?
PostPosted: Fri Jun 14, 2013 4:17 pm
What is the intake valve closing point on the cam you want to use?
PostPosted: Fri Jun 14, 2013 4:23 pm
Sorry but idk exactly what that means.
PostPosted: Fri Jun 14, 2013 4:48 pm
 Post subject: For beginners...
PostPosted: Fri Jun 14, 2013 5:15 pm
http://cochise.uia.net/pkelley2/DynamicCR.html
This article and links are a good start on the DCR thing, at the bottom of the page is a downloadable calculator that you can run on your computer...it will calculate the Intake Closing Event based on the cam information input on the second 'tab' of the calculator. This should make it much easier for him, and he can do the SCR calc on the last "tab" of the calculator. (Make sure to download it with VB6 runtime files, it will run on Win 7 64 bit with no problems).
Things he will need to know to input into the calculator:
stock bore is 3.4 (add over bores as needed .020,.030,.040,.060 are standard available sizes).
Stroke is 4.125
Rod length on the 225 is about 6.7" (it's closer to 6.699 but the rod stretches when warmed up and running so we can fudge a little).
If using a Fel-Pro head gasket- use a 3.52 bore size, and .039 thickness.
Stock pistons are flat and have zero CC volume.
Enter in the information on your chosen cam, you also can chose to advance the cam if desired when looking at the DCR to see if it will still run pump gas.
That should help you make better sense of the numbers within your control.
PostPosted: Fri Jun 14, 2013 6:21 pm
Ok ill take a look at that. From all of the engines ive ever messed with the piston are flat to the block. Can you do the same to these slants?
PostPosted: Fri Jun 14, 2013 6:48 pm
OK with the casting numbers I wrote previously. Do I have mechanical or hydraulic?
 Post subject: Err...
PostPosted: Fri Jun 14, 2013 9:27 pm
That's determined by the build or compression ratio how much you will take off the block, use the calculator to determine that.
Casting number doesn't matter since the rocker assemblies can be swapped back and forth, so that is moot. Look at the pushrod end of the rocker arms do they have threaded adjusters or are the just cups that are part of the rocker arm?
Users browsing this forum: DuckDuckGo [Bot] and 6 guests
