It is currently Tue Nov 24, 2026 10:19 am
PostPosted: Fri Jun 14, 2013 8:59 am
Car Model: 87 B150, 1970 Valiant 4-door
I know everydody says to put a fuel filter on the purge port when putting later carb on earlier car without canister, but is there a way to eliminate the port altogether?
I've been keeping an eye out for 70 & earlier cores to rebuild, but have had little luck (even ones that came off of appropriatly dated cars were still newer carbs w/purge port).
Are there parts I can leave off during rebuild, then tap and plug the hole without affecting carb function?
PostPosted: Sun Jul 21, 2013 4:35 pm
i just rebuilt my carb today and the bowl vent that goes inside the venturi and the purge tube are connected to the same area. only difference is that the little valve at the top closes the purge port with throttle applied so you can just cap it and be done...
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
