It is currently Mon Nov 30, 2026 3:12 am
PostPosted: Thu Jun 13, 2013 11:42 pm
My slant six is leaking coolant at what appears to be at the rear of the block within the bell housing (3speed manual). Is there a freeze plug or other area where the coolant might originate from? No coolant is in the oil and no visible head gasket leaks all around. It does not leak at start up but leaks pretty bad after fully warm and the cooling system is pressurized. Ideas???javascript:emoticon(':roll:')
PostPosted: Fri Jun 14, 2013 12:41 am
6 Pack Dart
If you have water leak inside bellhousing when warmed, sounds like you have a crack in the block. Recheck to be sure it is from inside the bellhousing.
Richard
PostPosted: Fri Jun 14, 2013 8:49 am
Thanks Richard. I'll check further. No possibility of it coming from the cam plug at the rear of the block?
[/img]
PostPosted: Fri Jun 14, 2013 8:57 am
6 Pack Dart
Not unless your block is cracked, the cam plug only holds oil in.
Richard
PostPosted: Fri Jun 14, 2013 9:53 am
Thanks again! I'm just trying to make it drivable for a short distance/time in order to ship it off the island to Texas where I can repair or replace permanently. Maybe some block sealer might buy some time?
PostPosted: Fri Jun 14, 2013 9:59 am
There is a block plug towards the back of the engine on the oil pump side of the block. It is possible it is leaking from there and rolling back or around the transmission. Check that plug to see if it is leaking. May not be a bad idea to put a little silicon on it and fit it back either way.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Fri Jun 14, 2013 10:12 am
I'll give it a further check later this afternoon. I believe the plug your referring to is the threaded drain plug, correct? For the short distances I have driven it (about 1-2 miles) it has puked out about 2 quarts. Starts up, warms up and runs smoothly with no leaks and then after full temp and pressurization the leak starts. I would think a cracked block would leak continuously or at least weep while not running or just starting up.
PostPosted: Fri Jun 14, 2013 10:40 am
If it's an early car...
Inspect heater hoses, heater core and flow control valve,...
Could be leaks there and dripping down onto the BH.
