It is currently Sun Nov 29, 2026 10:17 pm
Post new topic  Reply to topic  [ 64 posts ]  Go to page Previous 1 2 3 4 5
PostPosted: Fri Jun 14, 2013 9:40 pm
Just cups...and thete is like 7 bolts holding the rock assembly[/img]
PostPosted: Fri Jun 14, 2013 9:42 pm
Ok ill take a look at that. From all of the engines ive ever messed with the piston are flat to the block. Can you do the same to these slants?
 Post subject: Hydro..
PostPosted: Sat Jun 15, 2013 12:08 am
Just cups
just cups on the pushrod side of the rocker arm, you have a hydraulic cam engine... you can do the homework to keep it that way, or you can find an earlier mechanical lifter set of rockers and change out the cam/lifters/rockers and have a better/easier set of cams to work with.
The little 170 engine is a zero deck motor like you are imagining, the 225 can go that route with either decking or long rods and custom pistons, that is not as common for classic American engines to be zero deck. Like I said you have to plug the numbers in as decking .145-.175 off the block to have this done and having a limited combustion chamber space will put you into a race only engine (try it with your calculator for SCR...55 cc combustion chamber, and a .010 deck height with 0cc flat pistons....with a stock bore that comes to 10.79:1 SCR....you'll need some cam to bleed it down and run it on pump gas)...
When you mill the block that much, you end up with a one condition scenario...if the head warps you can take more out of the head...if the deck isn't quite flat, you have to get a new block and start over or use a different piston...so ideally when using the calculator, leave some deck height for "fudge", and leave some combustion chamber volume "just in case".
PostPosted: Sat Jun 15, 2013 7:27 pm
100 octane is readily accessible!! So i dont mind running it! So .010 off the deck and .060 off head is a good start? Im taking it to the engine shop first thing monday and im gonna go .030 over! Is this good?
Users browsing this forum: DuckDuckGo [Bot] and 6 guests
