It is currently Wed May 20, 2026 8:39 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
 Post subject: Re: Yes.
PostPosted: Sat Jun 15, 2013 11:37 pm
Yes, any time you adjust the lower control arms you need to loosen the LCA stud nut to allow it to "move", then you make the adjustment, then tighten the nut back up and you're good to go.
Oooo... This I never knew. May explain why I've had trouble maintaining long term ride height adjustments...
