It is currently Sun Nov 29, 2026 6:09 am
PostPosted: Mon Jun 10, 2013 2:12 pm
The closer I get to getting the 225 back in the wagon, the more I discover needs attention. See below. Arrrgh. The latest is the tie-rod end bushings, and the rubber body bushings/mounts on top of the front wheel arms. All are looking crusty, falling apart or half-gone. Can both of these be easily dealt with later, or do I have to handle them now?
PostPosted: Mon Jun 10, 2013 2:52 pm
replace them now while they are alittle easier to get at (with engine out). rubber parts are (relativly) cheap. you will be happier down the road.
1964 Dart GT
PostPosted: Mon Jun 10, 2013 4:10 pm
Absolutely replace all those rotted bushings and the ones that may look to be good; otherwise they will degenerate to dust in the first few miles of driving. Also any worn hard parts such as ball joints and tie rod ends should be replaced, and steering box inspected for wear. The car is unsafe to be driven in its present condition, and would be imposable to align the front end. All the parts to do the job are available from Rock Auto, and most any other parts store.
PostPosted: Tue Jun 11, 2013 9:08 am
More precisely, those are strut rod bushings rather than tie-rod bushings. With so much play in these bushings, your alignment will change every time you hit the brakes, which means you probably also have a brake pull.
These bushings should be correctly torqued and then the alignment should be reset. If these bushings are so worn, your other bushings are probably rough too. If you need to replace your upper control arm bushings, you should consider using Moog Offset Bushings (PN K-7103) for better handling.
PostPosted: Tue Jun 11, 2013 10:01 am
What he said. The strut rod keeps your lower control arm from moving forward and backward under load. If those bushings are shot, they should be replaced. The bad news is that if those bushings are hosed, your lower control arm bushings are probably in similar shape. But that's not such a big deal, as you need to remove the LCA anyway in order to remove the strut rod! May as well get it all while you're in there.
Here are a couple of great articles I found when I did this a couple months ago. Disassembly:
http://www.moparmax.com/tech/2011/vi_10 ... ips-1.html
And reassembly:
http://www.moparmax.com/tech/2011/vi_11 ... ips-1.html
Also, that rubber piece in the later pictures is a bump stop. It keeps your suspension from bottoming out metal-to-metal.
Escape Velocity Racing
PostPosted: Sat Jun 15, 2013 10:53 pm
Whoops. Thank you for correcting me: still learning what each piece of the front end is. Was also just educated about the torsion bars - I knew Darts had them, just didn't realize their exact role, over springs.
Well durnit, I don't have the capacity to do all of this right now: up to my eyeballs just trying to get things corrected on my engine build. I'll have to prioritize this, once I get the engine back together. I may delay re-installation though until I can get these bushings replaced.
The nut on the end of the strut rod in the control arm looks like a large star-headed nut, not a hex nut. Anyone know what size? Definitely don't have a star-socket that big....
PostPosted: Sun Jun 16, 2013 1:10 am
Car Model: 1964 Valiant V200
It's hex. 13/16 I think...
PostPosted: Wed Jun 19, 2013 6:23 pm
Mine's a large 12-point nut, not a hex: was calling it a star-headed nut. Hmm. May need to go get a socket to fit this. Jeez! Things are looking more than a little dirty and greasy under here.
FrankRaso - have not had any pull to my brakes, surprisingly. With the wear in these front strut rod bushings, you might think so, but it seems because there's so much grease and grime caked on under here, it looks like some of rubber was preserved because of it. The upper control arm bushings are looking a little cracked. I'm sure it should all be replaced together: but not sure how quick I can get to it.
Here's some general pictures of the state of the union.
 Post subject: Yep...
PostPosted: Wed Jun 19, 2013 6:56 pm
you just need a set of 12 point sockets and you should be good to go, normally that is a flanged nut for a 3/4" hex socket on the late cars (1967+).
Now would be a good time to upgrade to 11/16" C-body tierods and ends as well.
PostPosted: Wed Jun 19, 2013 6:57 pm
Regular 12 point socket fits just dandy.
 Post subject: Re: Yep...
PostPosted: Wed Jun 19, 2013 10:24 pm
Agreed, there are always upgrades I could do. But this rebuild could go on and on, longer than the 6 months it already has. :oops:
PostPosted: Wed Jun 19, 2013 11:10 pm
I was just going to say than now would be an absolutely ideal time to upgrade to disc brakes since you will be tearing the entire front suspension apart... :wink:
PostPosted: Thu Jun 20, 2013 1:11 am
Yah, that would be a nice conversion to do. However, I've never seriously considered it because I love the full-wheel Dart hubcaps which fit the 13" rims perfectly, but don't on the 14's. Kind of a silly reason not to do the upgrade, but here looks have always won out over functionality. I'd have to use the dish-type caps, and I'm not really there yet.
PostPosted: Thu Jun 20, 2013 4:52 am
[quote]Yah, that would be a nice conversion to do. However, I've never seriously considered it because I love the full-wheel Dart hubcaps which fit the 13" rims perfectly,[/quote]
Not much choice in 13â€￾ rubber these days.
PostPosted: Thu Jun 20, 2013 10:55 am
