It is currently Sun Nov 29, 2026 3:21 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Mon Jun 17, 2013 8:02 am
I am with CJ on this it can be done but be careful. Its no where ideal. Make sure you have a properly rated tire. I would think you can put a 235 65 15 on the truck it is slightly taller than and wider than your current tire size. I am not to concerned with the high of the tires as much as the width you need as much of a foot print on the ground as you can. It will help with traction, braking, and stability.
Make sure your trucks suspension is in top shape. With good shocks. If your bushings have not been changed in the last decade it due. Dont skimp on the trucks braking system and make sure you get a good digital brake controller installed. I am a fan of the prodigy brake controllers I have used a few of them.
Install a deeper trans pan and do a good flush of the trans. Install a trans temp gauge if that trans starts to get to warm pull over. Down shifting and hill climbing will tax that tranny so adding a good additional cooler will help.
As far as the gearing goes 3.55 is ok but I personally only tow with 3.92s up to 4.11s with about a 26.5 -27.5 " tall tire. Don't expect to see any kind of decent fuel milage because itsgoing to be lousy.
After you know the trucks in good shape go over the trailers brakes and suspension lube itall up. Check on your wiring and make sure your lights brakes and charging systems are all working as they should. Remember that everyone on the road is in a hurry and no matter how much of a stopping gap you leave in front of yourself be perpared for someone to cut in on you. With proper maintenance and attention to the details you should be ok to tow. But when ever towing its a calculated risk. Besafe out there.
PostPosted: Mon Jun 17, 2013 8:39 am
I fully understand the gravity of what I propose, that being said, what is so different (other than the engine) between my dads F150 shortbed with a factory towing capacity of 9000# and my old Dodge shortbed? They are both halfton trucks, they are both leafspring rears with semifloating axles, Both have power brakes............. I am a mechanic by profession so I am no dummy, I just can't see 5000# worth of difference between the two trucks.
Kevin
crossthreads are better than locktite
PostPosted: Mon Jun 17, 2013 9:00 am
PostPosted: Mon Jun 17, 2013 1:49 pm
I am a D-150 guy to,, and I have no idea what the frame rails look like on your Dad's F-150,,
but when re doing my 83 D-150,, I was surprised at how light the frame rails are, they are also C shaped, not boxed anywhere.
If you have access to the F-150,, it would be intereresting to get the trucks side by side and crawl under each and compare frame construction, wall thickness,, spring hanger mounting...
I am planning on doing some towing with mine also,, not near the tongue weight you are thinking of
PostPosted: Mon Jun 17, 2013 2:06 pm
The broad "150" label covers a great many potential differences. The "150" label is simply a broad generalization that the truck is rated to carry 1/2 ton of payload. Even within that designation there is broad variances. For example, my brother owns a 1983 Dodge short wheelbase van. It is a 150 chassis. However, in 1983 150 series vans could come with rear leaf springs rated to carry anywhere from 1100 pounds to 1950 pounds. There were several spring sets available with different part numbers. All were "150" springs, but had big differences.
Towing packages also changed a few things, even if they were installed on a 150 chassis. There could be bigger brakes, bigger cooling radiators, an auxiliary trans cooler, strengthened frame rails and joints, different specification tires, anti-sway bars, heavier duty alternators and wiring to power trailer brakes and lights, etc...
A 150 chassis can take a lot of abuse. But if you are wanting to tow 5000 pounds regularly, you really should either get a vehicle already rated to tow that much or spend the time to research what your truck needs to be "beefed up" to haul that much. There is more involved than just the rear leaf springs.
PostPosted: Mon Jun 17, 2013 3:14 pm
I believe you hit the nail on the head my friend, now that I think of it, I am almost certain the f150 has a boxed frame :-/
PostPosted: Mon Jun 17, 2013 3:39 pm
FYI- my 89 E-150 has a C-channel frame, not a box channel. My brother's 83 B-150 (that's a Dodge van 150 chassis) DOES have a fully "boxed" frame. It is a unibody with the C channel welded to the floor.
PostPosted: Mon Jun 17, 2013 5:29 pm
Let me also say, we would be talking at the most, maybe two trips a year, not like this will be an every weekend thing.
