It is currently Fri Nov 27, 2026 2:22 pm
Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2
PostPosted: Mon Jun 17, 2013 6:12 pm
Good luck with it.... Hey it's already broke so nothing to lose. A good experiment to try, please let us know how it comes out. Be careful of the thrust bearing recess.... You just never know, you may get lucky, I've seen 318 factory welded blocks....even if it doesn't work you were still lucky that bolt stripped, imagine if it held but was still cracked and failed after you assembled the engine!
PostPosted: Mon Jun 17, 2013 6:32 pm
I know I can't get it up to the temp it is supposed to be
I can remember seeing a photo,, where someone had immersed a casting in a pile of hot charcoal brickettes,, to get it hot for welding...
just a thought,, good luck
 Post subject: Lol...
PostPosted: Mon Jun 17, 2013 7:15 pm
Now, if you want to make sure the neighbors don't complain about the fire...dig a pit get a nice hole full of charcoal going, have everybody wear hawaiian shirts and hand out some pineapples...just don't tell them the pig in the pit is more pig iron than ham... :lol:
Your welder might appreciate a Mai Tai while waiting for the casting to cook.
PostPosted: Tue Jun 18, 2013 6:35 am
Hahah thanks guys. You're right about finding the crack now, Steve. Would have been much more frustrating to have found it while going down the road.
Do you think it's necessary to heat the entire casting, or could I just heat the problem and surrounding area? I've done a bit of reading but I haven't found anything too definitive.
EDIT: Also, votes for brazing as opposed to mig welding?
PostPosted: Tue Jun 18, 2013 5:59 pm
I'm no welding expert,but I have seen a few successful repairs to manifolds and blocks using a stick welder and " castmaster" rods.That was the brand name here in Australia,I have no idea whether they are available elsewhere.Personally,I wouldn't bother brazing,it's never really worked for me,but others may have better techniques.The only idea I could suggest is to "vee" it out to the root of the threads and perhaps just tack weld and then stress relieve by peening each tack as you go ,repeating until you have the whole job done......I would be treating it as a bit of an experiment,if you have a win,then you can decide if you want to use it . Make sure that when you re tap that heli coil hole that you use a square ended finishing tap,if you use a tapered tap and the screw the coil in you will have a very tight thread and may well crack the same area as you screw the bolt in. I guess the other advantage of digging a big hole and baking the block is that if it doesn't work you have a hole ready to bury it in! But seriously ,good luck with it,let us know how it turns out.
PostPosted: Tue Jun 18, 2013 8:55 pm
google search for "cast iron repair" turned up a slew of hits. Videos of techniques, etc. Maybe something among those offerings would help.
BC
PostPosted: Tue Jun 18, 2013 10:01 pm
Does the crack run all the way down the threads or is it just a chip off the block and the threaded hole isn't cracked?
If it's just a chip, just sandwiching the chip between the block and the bearing carrier might be all you need.
PostPosted: Tue Jun 18, 2013 10:17 pm
I'll say this once.
Throw it away, and get a different block Yours is toast.
I wouldn't waste time with it.
I certainly wouldn't waste money on it. It's Junk.
 Post subject: slant donor close
PostPosted: Wed Jun 19, 2013 5:00 am
This might be a good donor truck for you, add says Belleville, not to far from Ottawa.
http://ontario.kijiji.ca/c-cars-vehicle ... Z494218519
Mattelderca
78 NYB (gone now), two S series, three old Snow Cruisers and a Doo.
PostPosted: Wed Jun 19, 2013 6:57 am
I've looked at a few technique videos. Like I said, my neighbours a welder and has talked to us about it a fair bit.
The helicoil kit came with a square ended tap so no worries there.
Ceej, there is really no harm in trying at all. If it doesn't work, it doesn't work. I'm not spending any money on it.
Emsvitll, the crack goes right across to the threads and right down to where the threads end.
Mattelderca, I contacted that guy but he wouldn't go any lower than 6 on the truck. I know that's not a bad price but since I really don't need anything other than the engine, I can't justify it.
PostPosted: Sat Jun 29, 2013 7:59 am
Did you have a go at welding the block yet? Did you wear Hawaiian shirts and drink Mai Tais when you heated it up? Very interested to hear how it went!
PostPosted: Sat Jun 29, 2013 8:21 am
Hahah no, we never ended up even trying it. I bought another engine and transmission for 200 bucks and decided it wasn't worth the time and effort right now. I've gotta get my truck back on the road, but maybe ill mess around with the block after its running again.
