It is currently Fri Nov 27, 2026 7:29 am
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
PostPosted: Tue Jun 18, 2013 9:33 am
If you have a piston handy, slip in the bore and see what kind of clearance you have.
It may be as simple as the wrong rings in the box, let's hope!
Mattelderca
78 NYB (gone now), two S series, three old Snow Cruisers and a Doo.
PostPosted: Tue Jun 18, 2013 6:12 pm
I have reservations for sure on the machinist. Worried about it most of the night and that sucks. Bad enough getting sleep as it is at my age.
I did not specify a bore only asked to have it checked and bored to make it good. The block was so grunged up from hard black carbon oily deposits I just had him go through it and do what needed to be done.
He ordered pistons and rings and what I needed.
Ill be talking to them this AM.
Don't lose sleep over it,all can be fixed.The good thing is HE supplied pistons,rings and bored the block to suit,there is nothing he can say to really get out of it,he will just have to order the correct pistons and rings and he will have to try and remove the .030" pistons off the rods without damaging them so he can use them somewhere else.....all his problem. It's all the character building process of working on old cars and trying to find reliable sources of parts and / or workmanship. Good pick up for doing the right thing and checking his work and gapping rings and checking clearances....never take anything as correct,even if its done by a reliable machinist you trust,if it all measures up perfect you can tell them how happy you are with his work,if your not happy with something then question it.keep us posted, looking forward to hearing your successful outcome!
PostPosted: Thu Jun 20, 2013 12:28 pm
Car Model: 1963 Dodge Dart convertible
Contacted the machinist and took the engine to him today and looks like either wrong parts ordered or sent.
After micking the bore it came to 3.46 so he ordered .60 rings and pistons. I was pleased with his response and it was all low effort other than having to take engine off stand and put it in the back of the trailer and haul it up to Everett in the rain. I mean who ever heard of it raining in the Seattle area?
Thanks for all the help, support and encouragement. Will keep yall posted on progress and next major WTF!
John
Psychics will soon lead dogs to your body!
1963 Dodge Dart 270 convertible
PostPosted: Thu Jun 27, 2013 8:35 am
Got the lock back yesterday finally. Checked fitment of pistons before I left the shop and all is well. Clearance on the rod bearings is .002". I am ok on the ring gap as I am at .016" which is within the 010-.020" in the FSM.
So far everything is looking ok. I know one of the racing mods for the crank is to make the journals bigger but is this necessary for a stock or slightly modified engine?
Also cant seem to get the oil pickup tube back in the right position, keeps getting in the way of the pan, Ill be doing some picture looking and searching. It did go to the machine shop for cleaning but there doesnt seem to be any damage to it, the tube is not bent and the pickup is not loose.
Will keep yall posted.
John
PostPosted: Thu Jun 27, 2013 9:14 am
Car Model: 1964 Valiant V200
You probably mean journals smaller, as in undersize ground journals. That is done to clean up wear on the journals. Mic them two places 90 degrees apart and check against the FSM.
If yours are fine, and the journals are not too scored up you are good to go.
PostPosted: Thu Jun 27, 2013 9:32 am
John
Are you sure it's the right pick up tube, car vs. truck or something like that?
Did both pieces come from the same engine.
Mattelderca
PostPosted: Thu Jun 27, 2013 9:04 pm
yep crank journals were turned, I used plasti-gauge to check. Thanks for that.
The pickup tube is the same one that came out of the engine. Could be my befuddled brain messing with me, I find it does that a lot now adaze. Payback for my younger days.
I went to a newer peanut head for my rebuild and while painting the head and valve cover realized that the 63 valve cover will not fit the later model head so I will need to track one down for the engine.
Cheers.
PostPosted: Fri Jun 28, 2013 5:16 am
The bottom of the screen housing needs to match the angle on the floor of the oil pan. There is a taper on the pick up tube threads that allows the tube to be clocked and still remain hand tight.
PostPosted: Sat Jun 29, 2013 9:59 pm
So I put the pan on and was pondering its fit and I gave it a good smack and it appears that it rotated the pickup enough inward that the pan would now fit. I had no idea it was so closely critical that a few degrees would mess it up. I had put it kind of inline with the block since that is where it seem to be tight.
Oh well go figure. Should have thought about the bigger hammer!
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Rick Covalt and 5 guests
