It is currently Sun Nov 29, 2026 1:12 am
PostPosted: Thu Jun 20, 2013 6:55 pm
I just wanted to get some peoples opinion...i know that the aluminum being lighter is nice but does it hold up to the slant 6 manifold heat?
1984' Dodge D150 Utiline Bed
Slant 6 225, Holley 1920 Carb
A833 4 Speed O/D Transmission
PostPosted: Thu Jun 20, 2013 11:11 pm
Both are cast, iron and aluminum.
After a lot of trial error over the years.......my experiences have been........
1. The solid one piece aluminum are great for quick warm ups, cool downs (less heat soak) and better for good mileage. Warpage is minimal.
2. The iron is much slower to warm up and cool down (the stock choke may be set to stay on longer and some folks may hold their foot to the floor on hot starts) so mileage isn't as good and heat soak is much worse due to the iron retaining the heat longer...warpage can be unreal....
PostPosted: Fri Jun 21, 2013 9:25 am
Wow...i would have thought the aluminum would be more prone to warpage because of the lighter metal but i guess since it dissipates heat better it handles heat soak better
Are there 2 types of aluminum intakes 1 solid made from casting and 1 that is welded together?
 Post subject: Correct...
PostPosted: Fri Jun 21, 2013 9:27 am
Yes.
PostPosted: Fri Jun 21, 2013 9:28 am
Yes, for both the one barrel and two barrel.
Users browsing this forum: Google [Bot] and 7 guests
