It is currently Sat Nov 28, 2026 4:49 am
Post new topic  Reply to topic  [ 69 posts ]  Go to page Previous 1 2 3 4 5
PostPosted: Tue Jun 04, 2013 2:06 pm
Car Model: 1962 Dodge Lancer GT Black/Red
Thx Dad.
Yeah same cam you all came up with here. It has 9.5:1 compression.
I decided to go with the Holley 390 and save the super six stuff for my van. I can set the secondaries to open late and have that extra push to stay ahead of the semi's on steep climbs.
Yeah, I'll keep posting.
Ray
PostPosted: Fri Jun 14, 2013 9:03 am
ok so I think i have the timing worked out.
Rob helped me curve the distributor at his last picnic a couple of years ago and i had installed a new adj. vacuum can at that time.
I had to buy a new adjustable advanced timing light with tach. sears has one that is $85. it is the same one as actron and otc which is $170
I read a lot of timing articles throught this process and the most useful is Dougs vacuum advance article. Thanks Doug and Slant Six Forum.
So with the timing set with no pinging from mech. advance and then adding the vacuum with it's adjustment, i ended up with an initial advance of 12 btdc.
While i was out testing i noticed deq was open, so wth, why not see what happens. Damn, it passed lol, couldn't believe it. no smog equipment and I haven't even dialed in the carb yet.
Drove it to work today. will get the new tags this afternoon.
it doesn't accelerate as well as i would like but you can feel the power as it first begins to move, no dip but the accelration is kind of flat. then it criuses down the freeway very nicely at 50 up to 90.
this ia a new from the box holley 390. any input as to the next circuit to look at will be greatly considered. (thank you)
I think i will step the idle back up to 950 to 1000. it is at 850 to 900 now and does die at stop lights. and the idle vacuum is lower than i would like, (about 16) but it's not pinging.
:D
 Post subject: Couple ideas
PostPosted: Fri Jun 14, 2013 12:20 pm
it doesn't accelerate as well as i would like but you can feel the power as it first begins to move, no dip but the accelration is kind of flat. then it cruises down the freeway very nicely at 50 up to 90.
This is a new from the box holley 390. any input as to the next circuit to look at will be greatly considered. (thank you)
Sounds a little lean. If it goes flat on acceleration, it's not getting enough gas to make the transition from the squirtgun idle, to the trickle of the transition circuit and up to the hose of the mains... Holleys aren't 100% for slants out of the box. The low vacuum may be the cam needing to run a little more rpm at idle, or it needs a little more gas:
Either a little more idle mix is needed (back out the screw another 1/4-1/2 a turn), or the other item to address is the accelerator pump shot which helps anticipate the load on the engine, if the shot doesn't come in "on time" you get a hole or flat spot until the pump dumps the fuel into the bores. First thing is the qualify the setting between the pump arm and the bolt with the screw, and the lever at the fuel bowl...With the throttle held to WOT, you need to tighten the bolt adjustment until it is tight with a .015 feeler gauge slid in between (it has to have some gap or give or the lever can rupture the pump seal).
If that doesn't do the trick (getting the pump to work sooner), then you may not have enough shot...the quick way to play with that is to look at the throttle lever, specifically the pump cam... move the screw from the hole marked "1" and line up the the "2" hole in the plastic pump cam and insert the screw into "2"... if this gets closer but is not 100%, you'll have to change the cam to one that is bigger or has an aggressive profile.
Good Luck, and I recommend getting a copy of Dave Emmanuel's book "Super Tuning and Modifying Holley Carburators" if you are going to be working with Holley from here on out (there is probably one sitting on the shelf at Powell Books).
-D.idiot
 Post subject: Idling at last
PostPosted: Wed Jun 19, 2013 1:17 pm
I have, hopefully, cured the vacuum leaking issues and am now idling quite well.
Next is to see if i can determine what the original o8007 Holley 390 had installed for a power valve so i can try a little bigger one.
i can't believe how quiet this thing is with headers and the 2 1/4 exhaust to the rear.
Ray
 Post subject: It's...
PostPosted: Wed Jun 19, 2013 2:46 pm
It's a 6.5...what is your vacc. reading at cruise on the highway? (e.g. at 55 -65 mph)...that will help determine how much valve you could use...
PostPosted: Fri Jun 21, 2013 5:57 pm
Thx Rob,
cruises at 12
Ray
 Post subject: Hmm...
PostPosted: Fri Jun 21, 2013 6:50 pm
cruises at 12
I'd probably go no lower than 8.5... I use a 10 in my cars but they run at 16" under load..(I have used a dual stage for mileage/daily driving, but it wouldn't work as well in your case...plus the first stages are usually 9,10, or 12"...)
 Post subject: Ok Rob
PostPosted: Sun Jun 23, 2013 9:59 am
So I am going to the store for a 8.5 Pv. Being as it is located on the back side of the metering block, do you suggest changing to the upgraded metering block at this time?
Thx, Ray
 Post subject: Yes, but...
PostPosted: Tue Jun 25, 2013 8:20 am
Now would be the time, but if the block is meant for the larger carburator you will have to re-qualify your idle settings and check that the transistion
circuit is also not overly rich while driving it.
Users browsing this forum: Google [Bot] and 7 guests
