It is currently Sat Nov 28, 2026 11:19 pm
PostPosted: Thu Jun 20, 2013 4:50 pm
Alright so I can not get her started. Here is where I am.
I have gas. I know this because I forgot to tighten it down and got a small squirt
I have spark. I know this because I took an old plug and grounded it and saw a good blue spark
I am pretty sure I have compression Minty Fresh engine. New plugs, pistons, rings. Bored .030 over so minty fresh cylinder walls.
Timing reads 8 degrees.
How I got here.
I started by setting the timing marks to 0 degrees
Then moved the distributor so the rotor end pointed to the number 1 spark plug tower.
Now I had screwed up initially so I spun it over probably half a dozen times before I dialed the timing in.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Thu Jun 20, 2013 4:54 pm
If you have spark and fuel your timing has to be off. Does it try to do anything? A pop here or there or a backfire? There is the chance that you have your distributor 180* out. You can try turning the distributor while cranking to see if you get any reaction.
1966 Plymouth Valiant, 225, 3 on the tree, 8 1/4 3.21 sure grip, hyperpac, holley 650dp, holset h1c
PostPosted: Thu Jun 20, 2013 4:56 pm
If the timing is reading right and I have the rotor pointing to the number 1 distributor tower would it be 180 out?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
 Post subject: But is it?
PostPosted: Thu Jun 20, 2013 5:07 pm
Pull the valve cover, if you are on #1 and both the rockers for #1 are "loose" (you can wiggle them with your fingers), that's #1 compression and it should fire. If not roll it over until you are there and reset the distributor.
Also, make sure that you have set the lash loosely/cold, if the rocker screws are too tight it may not fire either.
Almost there....
:wink:
PostPosted: Thu Jun 20, 2013 5:10 pm
I set the valve lash 10 and 20 should I roll it back half a turn or so?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Thu Jun 20, 2013 5:37 pm
Okay I just checked and at 0 degrees the exhaust is slightly open. At 12 degrees or so both intake and exhaust are loose. I really think my machinist screwed up the crankshaft/camshaft alignment.
It may just be my camshaft though. I noticed on my camshaft card it said 14 degrees which is about where I am getting exhaust and intake loose.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
 Post subject: What cam?
PostPosted: Thu Jun 20, 2013 6:16 pm
10/20 is the stock cam, OCG 791 is .015 and .020...I would set to .017 and .022 cold for break in and then after break in set to the proper lash.
OCG has that at .050 tappet rise, so you would need to put a dial indicator with magnetic base on the head and check the lifter rise (pushrod end) from the cam base circle to .050 on the dial indicator and see how far BTDC the intake is opening...
 Post subject: Good News!!!
PostPosted: Thu Jun 20, 2013 8:46 pm
I found the issue. I checked my timing again and rotor position and I reset the valve lash as per Duster Idiot's recommendation. Tried again and nothing. I checked the carb again and while I was turning it over there was NO fuel going into the carb. So I pulled the throttle lever a bit and tired again. The car spat at me but nothing else. So I hit it with some starter fluid and it hit every time it would not turn over completely but I could hear the starter fluid popping.
So the question is why is the carb not providing fuel. I do not have the throttle pedal or kickdown linkage hooked up yet. I decided to wire the butterfly mostly closed to start with. I did start with it totally open though.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
 Post subject: Uh oh..
PostPosted: Thu Jun 20, 2013 9:14 pm
If you are getting fuel from the pump, but nothing at the carb, the needle and seat are stuck shut or the floats are positioned in a way to not let the needle off the seat and get fuel into the carb bowl...Time to open it and check the assembly and correct it...(which carburator are you using?)
After that I would set the throttle plate set screw about 3 turns in, the idle screw about 1 1/2 turns out to rough set it and let it rip...then adjust the screw once it lights to keep it about 2000-2200 rpm... make sure you have an under hood tach available (timing light/tach) to keep an eye on the rpm and have your watch handy to get the 20 minute burn in set)
Just an afterthought, once you get fuel to the carb bowl corrected, turn it over a few times without spark to fill the fuel bowl, then pull the throttle lever back and look down the throat to make sure you are getting a stream of fuel from the accelerator pump...once you have confirmed that, run it.
99.5% there, just one little issue...
PostPosted: Thu Jun 20, 2013 9:18 pm
Have you rebuilt the carb? If so, if the new needle has the rubber tip it may be stuck to the seat. A couple raps with a wrench at the inlet should free it up. Is the accelerator pump squirting? Trying to start it with the throttle open isn't really that great of an idea unless it is flooded. I would hook the springs up that keep it shut and try firing it with a little starting fluid or gas down the throat.
PostPosted: Thu Jun 20, 2013 9:42 pm
The carb has been rebuilt and when I pull the throttle lever it does squirt gas.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Fri Jun 21, 2013 6:11 am
If it is squirting gas from the shooters when you move the throttle linkage, then you should have fuel enough to start it if you are pumping the gas pedal during cranking.
PostPosted: Fri Jun 21, 2013 8:05 pm
Okay I need some help here. I obviously have screwed something up. I went back and double checked the valve lash. The method I used to set it was this. I set the intake just as the exhaust started to open and the exhaust was set just as the intake started to close. When I checked it 2 of the valves were not good and others were just slightly off.
I have pumped the gas while starting and I get some popping but no full start. I just checked the spark on the old plug which is an autolite I get a nice white spark on the NGK V-Power that I have used on the old motor the spark is pretty yellow. Could the spark plugs be the issue?
Also am I likely doing damage to my new camshaft?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Fri Jun 21, 2013 9:51 pm
Assuming you used some good assembly lube you should be OK.
For the timing take the no. 1 spark plug out, jam your finger in the hole and spin the motor over by hand until you feel the compression building. Keep spinning until the compression stops, stop and line up your timing mark if it is not already lined up. (If your balancer has spun or you are using a different timing cover obviously the timing mark isn't gonna mean a whole lot). Now check your rotor position.
It still sounds like your distributor is 180 out.
PostPosted: Sat Jun 22, 2013 7:08 am
Are the coil wires tight? If yes, are they hooked up backwards?
70 Plymouth Valiant 4dr
Users browsing this forum: DuckDuckGo [Bot] and 5 guests
