It is currently Sat Nov 28, 2026 11:45 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Sat Jun 22, 2013 8:39 am
Junior, I verified the compression stroke and that the timing marks were at 10 degrees btdc which is what I turned the distributor to. Both the intake and exhaust valves are loose indicating both are closed. The rotor was pointing dead at the number 1 plug tower.
ValiantBoyWonder, I double checked that the plug wires were tight and that they firing order was correct. All was well.
I get some sputtering and I can hear some ignition but still not turning over.
Anyone going to be or is in the West Georgia area? Maybe someone wants to stop by and give a hand? I will certainly return the favor.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Sat Jun 22, 2013 8:52 am
Newly built engine? It sounds like you have checked out the Timing correctly, leaving just the timing chain left. If you are not careful it's easy to get the timing chain a tooth off upon assembly.
PostPosted: Sat Jun 22, 2013 10:49 am
Oh, I ment the positive and negative wires that connect to the coil. If they are switched, she will spark but not fart.
70 Plymouth Valiant 4dr
 Post subject: Good news everyone!!!
PostPosted: Sat Jun 22, 2013 10:55 am
It is a brand new engine.
I called a friend over and he helped me out. We both sat and scratched our heads for a while and then we decided to check TDC again. Well Junior you were on the mark but off a little. Turns out my timing marks are about 12-16 degrees off. Its just enough to make it hard to find the problem. We got the TDC which by the way it is really hard when you have a 10:1 compression engine. We tuned the timing in close and got it to start YAY!!! I still need to dial it but it is close enough now.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Sat Jun 22, 2013 2:11 pm
Glad to hear you got it going. With 10:1 that thing has to sound pretty nice. Good luck with it.
Users browsing this forum: Amazon [Bot], Google [Bot] and 6 guests
