It is currently Tue May 05, 2026 1:33 am
 Post subject: A833 lubricant
PostPosted: Mon Dec 15, 2003 1:41 pm
Ok i just got a 81 ram with a /6 and a a833 w/ OD what is the recomended lubericant for this... This being a older desighn trans i would assume some sort of gear oil but i have read post where they suggest Type F trans fluid??
Frank
PostPosted: Mon Dec 15, 2003 2:05 pm
80/90 gear oil works best, you can use ATF, but i find the 80/90 is better and its thicker so theres less wear and no gear crunch on fast hard shifts :)
Justin
PostPosted: Tue Dec 16, 2003 6:39 pm
Thanks makes me feel better scince i have been topping it off with 80-90
Frank
