It is currently Sat Nov 28, 2026 4:30 am
Post new topic  Reply to topic  [ 37 posts ]  Go to page Previous 1 2 3
PostPosted: Tue Jun 25, 2013 4:44 am
try these links
http://vdlfuelsystems.com/?p=57
https://www.holley.com/TechService/FAQ. ... Carburetor
https://www.holley.com/data/Products/Te ... -7rev6.pdf
1963 AP5 Valiant 225 PB 904 Stock except extractors & 2 1/4 inch exhaust.
1962 S series valiant 225 PB auto. factory every thing. Full restoration job.
Currently on hold till AP5 is on the road.
PostPosted: Tue Jun 25, 2013 8:10 am
unfortunately, none of those links say anything about my problem.
1973 Plymouth Gold Duster
48,000 Original Miles
 Post subject: idle screws
PostPosted: Tue Jun 25, 2013 8:17 am
How many turns out are your idle screws from seated?
 Post subject: Re: idle screws
PostPosted: Tue Jun 25, 2013 8:25 am
I started at fully seated and kept trying to adjust them slowly until they were at the point they are at now. they are 2 full turns away.
PostPosted: Tue Jun 25, 2013 12:04 pm
Is the power valve leaking?
PostPosted: Tue Jun 25, 2013 12:28 pm
it's new. I heard Holleys have a check valve to prevent that from happening in their newer carburetors. but hey, I've been wrong plenty of times in the past.
PostPosted: Tue Jun 25, 2013 12:53 pm
Install a spare and see if that helps....your getting extra fuel from somewhere....
I would focus on getting a good power valve and float height. You may want to go a little lower.....
Check the needle and seat to see if there is some debris not allowing the fuel to be shut off. They are notorious for not seating and allowing fuel to dribble in.....
Users browsing this forum: Ahrefs [Bot] and 6 guests
