It is currently Sat Nov 28, 2026 4:07 am
PostPosted: Sun Jun 23, 2013 9:34 pm
The numbers stamped on the block are as follows, B 225 6 07. These were found under the #1 plug. From the info that I found using the search function the block was cast between 1960-67. The cast numbers are as follows, 04296: 2463430-19. What does the 19 mean? And the 04296? But that dosent give me a year the motor was assembled. Any help would be helpful, Thanks.
PostPosted: Sun Jun 23, 2013 9:49 pm
Site Admin
1966 225 June 7th.
Can't help with the -19. :shrug:
Shouldn't make much, if any difference. I think it's just the foundries mold number.
CJ
PostPosted: Mon Jun 24, 2013 9:49 am
This is an "early" 3 freeze plug SL6 engine block made from casting equipment (set) # 19. (-19)
PostPosted: Mon Jun 24, 2013 2:41 pm
I'm tearing apart an engine I pulled it from a 73 scamp but it has a super six intake. This has me worried, because the whole reason I got this motor is I wanted a forged crank motor. I'm worried though that this may be a cast crank block. I have the numbers from understand the #1 plug too, I was wondering if someone could decode these as well. The new motor is 7225p 5 9 2e, with the spaces accordingly. My original motor is 0225 t 6 7e
Thanks, Brandon
1976 Dart Sport
Currently under revision
PostPosted: Tue Jun 25, 2013 1:01 pm
Anyone?
1976 Dart Sport
 Post subject: numbers
PostPosted: Tue Jun 25, 2013 6:50 pm
we read it, just no one knows the answer yet!
PostPosted: Wed Jun 26, 2013 4:46 am
I'm not positive, but I think the "e" is designating a cast crank motor.
Users browsing this forum: Ahrefs [Bot] and 7 guests
