It is currently Sat Nov 21, 2026 8:03 am
 Post subject: Torque Plate
PostPosted: Sun Apr 28, 2013 6:03 am
Greg O got Exner G to drop off a slant six block that Greg had made race ready..but then was found to have a cracked bore...
it now lives on as a Torque Plate
http://www.flickr.com/photos/13718356@N ... 369887484/
from measuring the bore size,, it was bored .090 over.
From looking at the cut sections,,that case had a lot of end to end core shift,,( .100) the bores were consistantly thin towards the rear. Heavy on the front side.
Of the three bores that were sleeved,, they got a low as .090 on the rear bore wall and .220 to the front
Of the three parent metal bores,,, thinnest was .100 on the rear bore wall and .210 to the front.
the plate 1.5 inches thick.. that is where the measurements were taken.
PostPosted: Sun Apr 28, 2013 7:12 am
Thanks for taking the time to provide this information. We don't get to see the inside of many slant six blocks. At .090 over if the bores were perfectly centered the walls would be about .15 thick which is generally said to be a thin as you want to be. Since there is always going to be some core shift, the block should always be filled at least half way if you are going to use it for racing at 3.5" bore size.
PostPosted: Sun Apr 28, 2013 8:22 am
and thanks again for hauling it over here....
PostPosted: Sun Apr 28, 2013 1:47 pm
Functional art, it's so beautiful!
PostPosted: Mon Apr 29, 2013 3:28 am
Yeah, thanks for letting us know about this and posting the pics!
PostPosted: Tue Jun 25, 2013 7:35 pm
I am SO envious of the tool that was used to accomplish this. Darn, clearly I need a much bigger metal building.
1965 Barracuda
PostPosted: Wed Jun 26, 2013 5:54 am
Ddonner,,,good to see another Indy area slant sixer! Andy'gt is also in Indy,,wvenable is in Mooresville, akbmotorsports is in Columbus. Oldblue is also in Indy. Welcome to the group!
PostPosted: Fri Jun 28, 2013 4:53 pm
Glad someone got some use out of that Crappy Block!
Users browsing this forum: Google [Bot] and 8 guests
