It is currently Fri Nov 27, 2026 3:33 pm
 Post subject: head porting
PostPosted: Wed Jun 26, 2013 9:09 pm
I have my head off and bare, I was wondering if anyone had a diagram or even pics (step by step? :D ) of their porting job. Like a simple street strip port and polish or something. I really want to do this, and know I need to be cautious, especially since I haven't done one before. Its on a peanut style head, of that makes any difference, I don't know
PostPosted: Wed Jun 26, 2013 9:20 pm
Here are some pics of my porting. It isn't bad but I did not go to the extreme that some others on here have done.
Take your time and go slow. You need a selection of carbide burrs for your die grinder. You also need sanding drums and rolls to finish. It is very important to feel with your fingers.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Wed Jun 26, 2013 9:46 pm
Go to the FAQ. There is information and photos of band-sawed heads.
Big ports don't mean big gains, and there is water close to those ports. Don't cut like it's a solid mass of iron. It is not.
The best flowing heads don't necessarily remove a lot of material. They remove material that is an obstruction. The port floor has some material that can be removed, but once again, don't go nuts on it. Too large a port can create flow problems instead of creating better flow.
Read and search all the information here before you set a stone or burr to anything. Understand that these heads were never intended for high performance applications, and were designed around the 170 cubic inch engine. The head was never redesigned to support the 225 even after the 170 was discontinued.
Use caution lest you create scrap. It's happened many times thru overzealous porting.
2¢
PostPosted: Thu Jun 27, 2013 6:36 am
Thanks guys, I wasn't planning on going crazy on it, I had seen the band sawed head and studied it, interesting how close the water is, and like ceej said, the last thing I want to do is create scrap! :shock:
PostPosted: Thu Jun 27, 2013 9:16 am
Car Model: 1964 Valiant V200
I scrapped one head by not paying attention to the cross section pictures. We are very lucky that people took the time to post those pictures and share the info.
The thinnest part is the inside edge of the exhaust bowl (closest to the intake).
 Post subject: Fyi...
PostPosted: Thu Jun 27, 2013 10:58 am
Just FYI the peanut plug head is a little more meaty and forgiving than the drool tube heads, but since you are just doing a clean up, the places to work on are primarily the casting flash, smoothing out the ridge where the vavle guide is at (big pinch point there). And blending the bowl edges to the runner and guide.
 Post subject: Re: Fyi...
PostPosted: Thu Jun 27, 2013 1:31 pm
Just FYI the peanut plug head is a little more meaty and forgiving than the peanut plug heads, but since you are just doing a clean up, the places to work on are primarily the casting flash, smoothing out the ridge where the vavle guide is at (big pinch point there). And blending the bowl edges to the runner and guide.
:shock:
 Post subject: umm...
PostPosted: Thu Jun 27, 2013 1:50 pm
Yeah, could you clarify on that? I think I know what you mean, but id like to be sure :)
 Post subject: Yowza!
PostPosted: Thu Jun 27, 2013 1:57 pm
Talk about recursive...talk about recursive...talk about...
Corrected it, that's what i get for posting before going to a doctor's appointment...
Good catch. But yes, I was able to port the living crap out of a couple of peanut plug heads to match the fat pak cross section of 1.553H x1.272W and didn't break into the water jacket (note the standard clifford hpak cross section on both of my early and late manifolds was 1.336Hx 1.081W).
:lol:
For something like a stocker, super six, or offy intake clean up and blending are more key than 'matching and hogging'.
PostPosted: Thu Jun 27, 2013 2:44 pm
Alright, and thanks for clarifying that d.idiot , it makes me feel a lot less nervous :D so what you're saying is, for my mild build (225, no overbore, just rings, 9.5:1 comp, performance cam, and supersix intake 2 1/4 exhaust and whatnot) that I don't need to do the gasket matching? Just a cleanup and smooth?
 Post subject: I would...
PostPosted: Thu Jun 27, 2013 4:56 pm
Clean up and smooth, if going O/S Valves gasket match will be desired and looking at the pics posted where the leading edge of the valve guide is, I'd round/chamfer that leading edge...if you were going for all out race, eliminating it helps...(but will create a low flow due to wider passage on the street/super six setup...)
 Post subject: also...
PostPosted: Fri Jun 28, 2013 8:27 pm
So, I'm well underway on the porting, and I'm looking at my combustion chambers trying to decide what to do with them. I have seen some say it don't matter, and some say it does.
Is there actually a right answer? And if I do work on them, is there anything I should or shouldn't do?
 Post subject: Lol...
PostPosted: Fri Jun 28, 2013 10:50 pm
A slant six builder takes his head to a shrink and asks what to do about it...the shrink writes him a prescription for a bottle of tranquilizers and says give the Ford guy 2 before the time trial and whup him when he falls asleep at the light....
Technically there are loose rules on what to do and when it's right...
If this is a street build combustion chamber on a late head doesn't matter much in the way of polishing/etc. Take a moment if there are casting bumps or icicles to smooth those out, but the only real item of issue is unshrouding the valve from the chamber wall... Which will involve 2 intuitive steps... 1) is bolt the head to your empty block and scribing the bore outline onto the head surface to see the relation of the bore to the chamber, 2) is to put it back on the table and check the alignment with the head gasket...If you have some metal between the scribe mark and the side of the valve remove it up to the scribe mark with a small grinding wheel.... (This goes a long way on stock valve heads if really bad core shift has put 1/5-1/4 of the valve's circumference against the chamber/bore wall, effectively killing flow in that area...). Do not remove anything that will be under the fire ring of the head gasket, if you do you either need a wider bore head gasket or a new head.
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot] and 4 guests
