It is currently Fri Nov 27, 2026 9:33 pm
 Post subject: Proper head torque value
PostPosted: Thu Jun 27, 2013 8:57 am
Okay so I am seeing conflicting information. I saw on Docs site the head should be torques to 70 ft lbs my 65 Service Manual says 65 ft lbs and I think I found somewhere else on line 80 ft lbs.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Thu Jun 27, 2013 9:18 am
So, what's your point? Is there a question in there somewhere? I have mine torqued 5 lbs over what the book says if that answers your question.
PostPosted: Thu Jun 27, 2013 9:19 am
Car Model: 1964 Valiant V200
If Doug says 70 I'd torque to 70.
PostPosted: Thu Jun 27, 2013 12:11 pm
Thank you robertob. That was the answer I was looking for.
69a100, I do not want to over torque because I have a 10.5:1 engine. If I over torque it and the compressed gasket gets changed because of it I could cause all sorts of problems.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
 Post subject: Bolts, right?
PostPosted: Thu Jun 27, 2013 12:53 pm
Head bolts I would go as doc says and do 70, if doing a "recheck" after running it for a while (say a good highway trip after break in/shake down), then you might do 75 on the second round. I think 80 is what is spec'd for the ARP studs.
