It is currently Fri Aug 28, 2026 12:42 pm
 Post subject: How my slant sounds...
PostPosted: Wed Jun 26, 2013 9:50 pm
http://www.youtube.com/watch?v=8QCYzAMb9g4
What do you think? A little too "hot" of a cam?
'81 W150 on Propane... Oversize valves, Oregon Camshaft cam, 10:5 static CR, Distributorless ignition, megajolt timing controller, PowerTrax lockers.
PostPosted: Thu Jun 27, 2013 3:24 am
I like it!
Will
PostPosted: Thu Jun 27, 2013 11:53 am
Sick! Would you mind sharing the cam specs with us? :D
PostPosted: Thu Jun 27, 2013 3:54 pm
I think they're actually posted here somewhere.
It's an oregon cams grind, with a little bigger intake than exhaust.
I made a mistake when I bought it... It's set up to make good horsepower and midrange torque. Except that the definition of "midrange" isn't what I want it to be.
Here's the camcard:
Part of the sound comes from the fact of having about 10:5 actual CR, and the other is that it's running on propane and I seem to have a hard time getting the mixture optimized. It's a little bit rich right now.
PostPosted: Thu Jun 27, 2013 8:01 pm
sounds pretty good to me.
