It is currently Fri Nov 27, 2026 8:10 pm
 Post subject: Intake gasket
PostPosted: Fri Jun 28, 2013 9:48 am
so this is my 3rd time im putting a remflex gasket on my intake. i finally found out your only to tighten it to 5 or 7lbs. but does anyone have any other good advice on anything else to do to prevent any leaks?
PostPosted: Fri Jun 28, 2013 10:19 am
Mill the surfaces flat is about the only other way to go...which if you are running headers is going to be a tough one to do if the flange is warped or the welds aren't flat...
Another item to check is the mating surface height of the intake and exhaust flanges if they are uneven the triangular washers will not clamp evenly between the two manifolds as they are mated to the head... similar issues exist then mating an offy or stock super six intake with headers or dutra dual duals, the headers/dutra mating tabs are almost 1/2" thick and the offy/stock intake is only about 3/8" thick causing the triangular washers to be 'cocked' and only apply clamping force on the thicker flange...the issue is resolved by either judicious grinding of the tab/ears or having the thicker flange milled down.
It's always best when putting together a new combination to 'mock it up to the head without the gasket, look at the washers and fix that, and also see if there are other considerations (i.e. header down pipe to steering linkage/crosslink interference)...fix/dent/grind those items re-check the fit and then install with the gasket.
Users browsing this forum: Ahrefs [Bot] and 5 guests
