It is currently Fri Nov 27, 2026 4:59 am
 Post subject: Cam clearance issue
PostPosted: Sun Jun 30, 2013 1:03 am
I had my 'master' machinist (that's his name for himself) replace my cam bearings when I had him bore and hone the block. I know...now I'm worried.
Today, for the first time, I lubed up the cam journals (just got the cam back from being re-ground), and tried installing it. The rear-most cam journals all went in smoothly, and as you can see in the photos below, when it's just the three cam journals in the first, second and third cam bearings, the camshaft turns easily, as it should.
That stops when I get to the first cam journal (also the widest), and try to continue. There's resistance, big-time. Tried tapping it in gently, and then using a socket wrench to rotate it. It rotates, but really wants to rotate right out of it. Upon examination, some portion of the front cam journal is digging into the first cam bearing.
What could be causing this and how do I go about diagnosing and rectifying it? Seems like there's just one thing after another with this engine rebuild right now.
 Post subject: ???
PostPosted: Sun Jun 30, 2013 1:20 am
That wear pattern isn't right...being that the cam bearings are incrementally sized narrow to the rear and wider in dimension to the front of the block the cam during assembly always tends to want to "fall out the front".... but with a heaping of lube on the journals you should not have a problem turning the cam by hand if a head bolt is installed in the nose of the cam for installation.
What kind of assembly lube are you using? It's kind of hard to tell if using a clear non-moly assembly lube (like Lucas or Autozone Generic), or a moly suspended paste like Napa's assembly lube or Isky's Assembly Lube (my favorite).
"Man I swear if things get better I'm writing an article on engine assembly for this board...."
PostPosted: Sun Jun 30, 2013 1:29 am
The Lucas stuff was all I could source locally within 5 miles of me. I put a good deal of it on too. Greenish in color. It was all smooth except for Journal #1, where i seem to be having the problem.
PostPosted: Mon Jul 01, 2013 12:12 am
Master machinist eh!
Most likely crap or damage between the bearing and the bearing bore at the point where the wear mark is. Measure the bearing ID for out of round.
If out of round, pull bearing and find out why.
There are a few other less likely possibilities. I would start with the above idea though.
Looks like you are having a lot of fun with the rebuild!?
Don't let it get to you. You are learning valuable lessons, and your build will be stronger for it.
Good luck and stay calm :)
Brendan
1963 AP5 Valiant 225 PB 904 Stock except extractors & 2 1/4 inch exhaust.
1962 S series valiant 225 PB auto. factory every thing. Full restoration job.
Currently on hold till AP5 is on the road.
PostPosted: Mon Jul 01, 2013 3:02 am
When we rebuilt Ryan's Dart some years ago, we had the same thing happen. I don't remember why it happened, but Doc told me the probable reason back then. He had seen it several times before. I took the block back to the machine shop and they shaved the ID of the cam bearing and that took care of it. It never gave him any problems. If your guy is a Master machinist he should be able to fix it right up.
Rick
PostPosted: Mon Jul 01, 2013 4:53 am
SSRN National Champion
My last two rebuilds had the same issue. The machine shop also took some material off the ID of the two rear cam bearings. It could be possible there is a small amount of contorsion occuring in the engine block.
Ron
PostPosted: Mon Jul 01, 2013 5:11 am
That's what I mentioned in a previous post about checking alignment with the cam. Give the journal a polish to make sure there's no nicks etc.... Then you have a choice of either scraping the bearing to get required clearance or changing the bearing. Chances are he rolled the bearing edge slightly during installation or there is a burr or crap on the tunnel as mentioned previously. Check everything... He rebored it? Check them, check everything then you have a game plan when you either speak to him or take it elsewhere to get it sorted. I personally don't paint things till the engine is assembled unless you're prepared to mask up gasket faces etc. It's your call but clean, paint free surfaces are my suggestion if you're after a leak-free assembly
