It is currently Fri Nov 27, 2026 5:10 am
 Post subject: Harmonic Balancer
PostPosted: Sun Jun 30, 2013 6:48 pm
I'm taking out my slant for a rebuild after the oil pump imploded. It's a '67 225.
I pulled my harmonic balancer, and I see that the timing mark is a few degrees (clockwise as you face the front of the engine) past the crank key slot. Is the timing mark supposed to be aligned with the key slot? Does this mean my outer ring has slipped, or is this the proper spot?
I want to make sure when I put her back in that I have the proper mark placement. When the distributor button is at tower 1, the #1 piston should be at the top of it's stroke, should the timing mark also be at TDC? I assume so, but it's been a long time since I worked on an engine, and I'm just learning the in's and out's of the wonderful slant six.
Thanks all,
BG
PostPosted: Sun Jun 30, 2013 7:04 pm
Site Admin
Nope. Have the shop check TDC. They will have the correct tools. Verify it lines up there. If not, send it in to the Damper Doctor, or snag a new one.
It's not necessarily right on the key, and it's hard to tell just looking at it. I don't have any that are dead on the key.
CJ
 Post subject: Yep...
PostPosted: Sun Jun 30, 2013 7:08 pm
None of my 225 dampers '67-80's are on the key they are just to one side of it...
PostPosted: Sun Jun 30, 2013 9:50 pm
I remember talking to one of the damper rebuilder houses a long time back - they said spec was 5 deg off the key way.
 Post subject: Thanks...
PostPosted: Sun Jun 30, 2013 10:36 pm
I measured the angle, it look to be about 5 degrees off the key slot, so it appears to be at spec location, if you're information is correct. Also, just prior to the oil pump failure, I had found TDC and the timing mark lined up with TDC on the timing cover gauge, so....I think I'm good with this dampener (I tuned it to about 12 degrees advanced, and it ran great). 46 years, who knows how many miles/engines, and the dampener is still good. Cleaned off the crud, a little paint and she looks like new.
thanks all,
bg
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 26 guests
