It is currently Thu Nov 26, 2026 11:43 pm
 Post subject: valve cover differences
PostPosted: Thu Jun 27, 2013 9:35 pm
Car Model: 1963 Dodge Dart convertible
How many different valve covers are there for the slant six? I thought there was only one. Other than offy anyone have any suggestions on an aftermarket chrome one? Any problems fitting them?
Thanks
john
Psychics will soon lead dogs to your body!
1963 Dodge Dart 270 convertible
 Post subject: No.
PostPosted: Fri Jun 28, 2013 7:32 am
There are variations by generation, and aftermarket there are 3 or so.
1960-1980 the foot print is the same and these all fit the mechanical lifter heads...the difference will be the early-mid-60's has the ribbed cover with the stove pipe breather/pcv/oil fill tube. The late 60's brings on the standard one we know that has the oil fill/pcv grommet/breather with a smooth top. 1981-1987 heads have a 'dent' or bend at the front of the head for the valve cover mating surfaces so if you got a head off a late truck...you need that type of valve cover.
After market you have the chrome smooth covers by offy, clifford, china for the standard heads, and the finned cast cover as well. Mopar Performance at one time did offer a chrome cover for the 1981-1987 heads (i think someone had one for sale on here a while back, but was $$$).
There may be others but that covers the basics, kind of sounds like you need to go on a junkyard raid for a 1980's truck/van valve cover (grab two in case one doesn't seal.
PostPosted: Sat Jun 29, 2013 9:58 pm
thanks DI. Im still waiting for my brain to make a decision. Gotta get to the more closer time to needing so I can freak out some more!
Cheers.
PostPosted: Sat Jun 29, 2013 10:44 pm
If you like shiny things (and who doesn't?) I say get a stock stamped steel valve cover and get it media blasted and then polished and powder coated clear.
 Post subject: Ya know...
PostPosted: Sat Jun 29, 2013 11:00 pm
If your head is a standard version like Reed has suggested, and not the hydro head version...I do have a 1990's clifford chrome valve cover I might make a deal on fer ya...(better than the chinese ones...).
:wink:
PostPosted: Sun Jun 30, 2013 10:12 am
do not. i repeat, do not buy any of the Chinese valve covers. They will not seal, you'll ruin your pretty engine with oil leaking out from all over. if you're willing to do a little engineering, grinding/cutting, then it'll work for you.
Reed's got the right idea there with using the stock one.
70 Plymouth Valiant 4dr
PostPosted: Tue Jul 02, 2013 4:08 pm
Thanks guys, always a clear response here! I am still looking for a steel one and the engine is not hydraulic. What is the difference between the hydraulic and mechanical head cover-wise?
Thanks
John
 Post subject: It's...(with pics)
PostPosted: Tue Jul 02, 2013 5:27 pm
On the back passenger fender side of the valve cover the difference is noticeable...mechanical cover it straight and follows the line of the head,
hydraulic- about 2-3" at the front of the head the cover has about a 1/2" jog toward the rocket shaft...
So here is a pic of the 'bend in the valve cover near the oil fill hole and alternator bracket on an early 80's truck motor.
I laid a mid-60's valve cover over the hydro cover so you can see that the 60's to 1980 valve covers should make a nice straight line parallel to the passenger fender, and the hydro cover has the noticeable jog (unless you are looking at it with the alternator and heater hoses in the way...)
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 7 guests
