It is currently Tue May 19, 2026 6:48 am
 Post subject: suspension design
PostPosted: Fri Jul 05, 2013 5:54 pm
Im replacing the original rear springs in my 1951 DeSoto with Late B lowering springs (2") Im hanging them with new fron hangers and sliders. The rear axle is a 2001 Explorer 8.8 narrowed a couple of inches. I used A body spring plates with built in shock mounts.
After measuring everything in every direction 50 times I let the axle and mounted springs hang by the stock shocks. Everything swung neatly into place. ....no pushing,clamping or fudging. Weld and go.
Why do I even measure?
PostPosted: Fri Jul 05, 2013 6:48 pm
It gives you something to do while the welder cools between duty cycles?
 Post subject: Lol...
PostPosted: Fri Jul 05, 2013 8:30 pm
It just makes you look busy so someone doesn't notice that everything just fits like it should and you didn't even break a sweat... then after all the gruelling measuring you can say "Whew, that was a tough one..." and get a beer...
Also if you made it look easy the neighbors might think you're a pro and bring all their projects over to you since it easy for you.... :lol:
PostPosted: Sat Jul 06, 2013 2:58 am
Nice work. We'll see how it tracks... What are the shock mounts on the car end?
PostPosted: Sat Jul 06, 2013 7:10 am
Probably a dam metrical rooler anyways. :lol:
PostPosted: Sat Jul 06, 2013 7:31 am
The stock shock mounts are on the chassis crossmember directly in front of the axle. They are the same as an A body except they are in front of the axle. I just turned my A body plates around .
I have the chassis on a trailer . It is blocked and clamped at unloaded ride height.
I had the axle on jack stands and the hangers and sliders clamped in position while I mounted the springs and shocks. I cycled everything using a floor jack . When I lowered the axle with no stands or clamps it just swung into position.
Next up I bolt everything together (just to hold things in place) before trailering to the machine shop for welding.
Then on to engine and trans mounts......
PostPosted: Sat Jul 06, 2013 3:02 pm
I will remember all of this when I get around to an IRS swap in the 64 Dart...
PostPosted: Sun Jul 07, 2013 7:11 pm
rear crossmember/trailer hitch fabbed and ready for welder
longer wheel studs added to 8.8 for wheel spacers and drag wheels
rear sway bar installed (77 Lincoln 3/4")
........and back to work.
PostPosted: Sun Jul 07, 2013 7:30 pm
Why do you even measure???
Cause ya know what happens when ya don't!
Even a blind pig finds an acorn once in a while.
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
