It is currently Fri Aug 28, 2026 7:28 am
PostPosted: Sat Jul 06, 2013 6:15 pm
 Post subject: You need...
PostPosted: Sat Jul 06, 2013 7:19 pm
Better put in a driveline loop, if the shot compromises the front u joint during a shift it ain't going to end pretty.... (hopefully the clutch will wither out before it blows also...so far all mine have...)
Looks like fun otherwise.
:wink:
PostPosted: Sat Jul 06, 2013 7:27 pm
good advice, I blew out my rear U joint already! (I posted a pict of the new one in my last thread)
I think there is a loop laying around the garage from the last chevy project. I am still undercoating the Car and doing other stuff to her so I will look into getting one bolted on. My new Molded carpet should show up on monday so why not run more bolts thru my floor ;)
Next is moving the battery to the trunk and getting the cold air intake on.
but next is super six'n the 4 door "Emma"
PostPosted: Thu Jul 11, 2013 7:31 pm
Thanks to my Buddy in Greenwood she is also looking better.
PostPosted: Thu Jul 11, 2013 7:37 pm
Cool! Keep us posted.
PostPosted: Mon Jul 15, 2013 5:42 pm
Site Admin
That's looking sharp Neil! :D
Your going to like the Clifford Intake. Did you get your shorties?
CJ
PostPosted: Mon Jul 15, 2013 6:35 pm
nahh no shorties, Just running a block off plate on a stock exhaust manifold that I had the machine shop play with. I need to get my secondarys to open a little earilyer but that is my only complaint.
Emma sure likes her super six setup with that 500cfm 2bbl that Marilyn gave her.
so the swap was a win for me
 Post subject: Ol' Yeller...
PostPosted: Mon Jul 15, 2013 7:02 pm
Given what you are doing, it probably needs the short yellow spring in the secondary pod.
:wink:
PostPosted: Mon Jul 15, 2013 7:12 pm
sounds good. I will give that a shot this weekend
Thanks! :)
My Four door "Emma" was playing sick.
