It is currently Thu Nov 26, 2026 9:37 am
 Post subject: Main bearing clearance
PostPosted: Sun Jul 07, 2013 5:13 pm
My mains are .002........is this ok? what should rod bearings be?
PostPosted: Sun Jul 07, 2013 5:48 pm
#3 0.038
#2 0.030
#1 0.002
 Post subject: Clearances...
PostPosted: Sun Jul 07, 2013 6:47 pm
mains should be .0005 to .002 if forged crank... I would not want them to be on the edge of the loose side.
rod bearings if a forged crank would be .0005 to .0025...again I would not want to be on the end of the loose goal post.
PostPosted: Sun Jul 07, 2013 7:57 pm
Are my numbers to loose?
PostPosted: Sun Jul 07, 2013 9:56 pm
Im such an idiot! 2 3 and 4 was in mm.....so actually 0.0015
PostPosted: Mon Jul 08, 2013 10:55 am
Car Model: 1964 Valiant V200
See if you can switch around the non-thrust shells and get a different number.
Do you have a ball-end micrometer (or a ball bearing of known diameter and a piece of vacuum hose)? Measure all the shell thicknesses, then measure the journals and the main bearing bores. Swap parts around to get the most even spread of clearances.
I personally would be fine with those numbers if it is a used (not reground) crank.
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
