It is currently Fri Jun 12, 2026 3:17 am
PostPosted: Sat Jun 01, 2013 6:16 am
Car Model: 1964 Dart 270
Uploaded with ImageShack.us
Is this a useable electronic distributor, can the part be swapped to a slant points distributor and work? :D
 Post subject: Nope..
PostPosted: Sat Jun 01, 2013 8:35 am
Notice that it has no moveable pickup plate and no vacuum advance or mechanisms...this is a 1981-1987 ESC distributor....unless you are going to EFI and using the PROM to affect timing or racing with a static timing setting, this will not work for you...Nothing interchanges with the EI distributor except maybe the reluctor...the EI parts from an EI distributor can't be readily transplanted to a points distributor unless it's a 1972 points body (that year they changed the body and mainshaft to be like the 1973-1980 EI distributors).
PostPosted: Sat Jun 01, 2013 10:06 am
Thanks DI, just curious about it. Guess I have no use for it then......
PostPosted: Sat Jul 13, 2013 12:24 pm
It also appears to be an 8 cylinder distributor.....
crossthreads are better than locktite
