It is currently Wed Nov 25, 2026 12:34 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Tue Jul 16, 2013 6:38 pm
This happened before I had any manuals, and I saw no reason for the pump leak, but the previous owner had warned me about it, so maybe there was some pre-bent chassis parts! :lol:
Olaf
Aspenized
 Post subject: You might...
PostPosted: Tue Jul 16, 2013 7:05 pm
You might be able to get the OEM 5/8" rotor pump out after removing the cover plate, it is pretty close. Pulling a 7/8" melling pump in the car requires that manuever after jacking it up to get it out...the M66HV pump is pretty much a pull the engine affair unless you let mongo pull it out...
