It is currently Fri Jan 02, 2026 3:22 am
 Post subject: Honing Plate
PostPosted: Tue Jul 16, 2013 6:56 pm
Just got this back from the machine shop. It was started by my friend Bobby years ago, but never got finished. So I had the holes taken to 3.55. It's an inch and a half of aluminum. I have decided to bore my 170 as the block just looked a little too loose. So I am going to use this now and see how it works.
PostPosted: Wed Jul 17, 2013 6:19 am
Cool! Should work great. I have one in steel that is 2" thick - HEAVY.
PostPosted: Wed Jul 17, 2013 1:10 pm
is aluminum strong enough to get the desired effect?
PostPosted: Wed Jul 17, 2013 1:37 pm
Car Model: 1964 Valiant V200
Should be. My machinist made one from Aluminum, not even as thick as this one. It just needs to give the headbolts something to torque against.
PostPosted: Wed Jul 17, 2013 3:21 pm
Wouldn't steel be cheaper then the aluminum? Machining the aluminum would be easier and probably make up the difference.
 Post subject: Steel or Aluminum
PostPosted: Wed Jul 17, 2013 6:00 pm
Well Bobby did make a steel one that I used to use. But I left it in the good care of one Sir Will of Glochester! So I took the other less travelled path and finished this aluminum one. Thanks Bobby!
PostPosted: Thu Jul 18, 2013 5:55 am
I am sure it is stiff enough to replicate the head stresses/strains. I have wondered if just running some bolts into the block with some individual washers/spacers wouldn't give you almost the same effect.
